Certainly? How can you tell? The only way to find out is blind auditioning, which isn't something people normally do.
Whoops, wrong person quoted it seems.
Good point (and a great post right there).
Note that I did not say there's no difference, I'm only saying I can't hear any. And believe me, if there's a way to improve my system by spending a couple hundred bucks on a DAC, I'd happily do so. I'm at a point where (to the best of my knowledge) the only way I can improve my listening experience is buying headphones for at least $1500, if not more.
P. S. None of the DACs you're referring to are single-chip integrated solutions. For instance, PCM1794 has a current output (rather than voltage) so it needs an I/U stage, which is a simple way to screw it up with sup-par circuitry. They're also easy to screw up by poor power circuit, even just by poorly routed PCB, since they're designed to operate on USB power like 2704.
By the way, I have listened to PCM1794, too, among a couple other DACs I couldn't tell any difference between.
Oh, I didn't realize. I guess whoever slaps a chip onto a PCB with 5 traces is free to invent a unique name for itThe SkeletonDAC is shown in that first graph. It is completely a single-chip integrated DAC based on something called the PCM2704.
Measurably - sure. But in this thread we're only interested in audibility, right?They're all very low-performing DACs compared to most of what's available today.
I am evaluating a Chord Hugo 2 at the moment, and it is audibly transparent. And so is the ODAC.
By definition any DAC that's decent should produce the exact same output.
I'm not saying it isn't true, but, the Problem starts with the AD Conversion.Not true. It may be easy for even the cheapest of DACs to have a neutral frequency response, but DACs measure very differently in terms of timing accuracy, noise floor modulation, noise shaping, and distortion. Rob Watts' approach with Chord DACs addresses all of this in ways no other DAC manufacturer has achieved. Check out these posts for starters. You can look further into it if you like.
https://www.head-fi.org/threads/chord-electronics-dave.766517/page-344#post-12938860
http://www.head-fi.org/t/831345/chord-electronics-hugo-2-the-official-thread/1665#post_13342285
At some point the signal was analog (nowadays potentially only in the studio just at the microphone). After that it's digital up until we play it. Recorded into the PC, mixed, mastered on the PC, and published on CD, all digitally. The Digital Data describes the Analog Waveform. Any DAC's Job is to produce the Waveform that's described by the Digital Data. How this is done is pretty irrelevant really. Either you produce the desired output or you don't. There might be differences, but i doubt they are massive,
Differences can come from any Amplification done by the "DAC". But that's not the DAC part, that's the Amp part. Even if it's in the same housing and is only called a DAC.
I don't doubt that DAC's measure differently. I don't doubt that there are differences between DAC's (as in units, not Chips). I only doubt I could here them, or that they are big enough for me to care.
This would asume the ADC conversion was perfect.Again, not true. Please research these things instead of spreading misinformation. Or better yet, listen to DACs before claiming how they sound.
Rob Watts' philosophy is that a DAC's job is to get closer to reproducing the original analog waveform before it entered the ADC (not to merely reproduce the digital samples as they are), which requires advanced mathematics, filtering, and so on.
IF the goal is to reproduce the Analog sound before the very first digital conversion, the only way to do this would be doing the exact conversion the studio did backwards. Since you can't now what ADC was used while recording, this is potentially unachievable. IF the difference between DAC's is as big as you claim, the differences between ADC's should be similarly big. That means the ADC used in recording would have the same amount of influence on the sound the DAC has. You would need a matched DAC for any album to come close to that goal
Also, i'm not spreading misinformation and i'm not claiming anything. I'm just stating an opinion. My opinion is, the best we can achieve (and what we should aim for) is to reproduce what the Mastering engineer heared while finalizing the song. This is the closest to the Artists "intentions" we can get (except maybe live albums). But really, we all do this so our music makes us happy. Buy what ever gear makes you happy while listening to great music.
I think there it's more of how headphones respond to the different sources. DACs generally measure flat so what accounts for the sound differences?
It's likely how the headphones react to the output of the source.
If you don't believe us, try out different sources with different types of output devices(iems,headphones,speakers). I don't think it's strictly the output impedances explain the different sounds, although significantly high output impedance does change the frequency response to create a noticible skewed sound.
IME, some sources do sound brighter than others. I do find certain chip based DACs sound different from other chip based ones. ESS for example can make headphones sound forward and highs more prominant.
If we want more accurate measutements, we need accurate headphone output measurements from different sources, and compare.
