I'm just wondering if there is a way to change any headphones, IEMs with LDAC from AAC or SBC to LDAC without using any Android device? The items are Soundcore Liberty 3 Pro and Soundcore Life Q35? Thank you for any help in advance
There is no way at all can the codec be set at the headphone level. The host device must also support the codec. If you pair the LDAC wireless headphone to a device that doesn't support it, the headphones will either default to the crappy SBC codec or refuse to connect at all.
Oh I get that. The issue is how to change the setting from the headphone. Seems like I can’t change it through the A55 as the cans themselves how to be on the correct setting
