soccerdude84
- Feb 1, 2013
I just realized I've never actually owned a pair of circle phones, so I was wondering what the slight differences were, if any. Comfort? Soundstage? Aesthetics?
It depends , some of the Beyers are amazingly comfortable whereas the HiFiMANs being circular are horrid to wear for long sessions , the sound difference will be affected by the foam and layering , more the space more noticeable dips at a particular frequency
The first headphone to have a high tech earpad was the dt48 by Beyer
I don't think the shape of the HiFiMan's pads is so much the problem as the weight of the headphone and the padding in the pads. I have AKG K550s with round pads that, like the Beyers, are perfectly comfortable.
If you notice the inner part of HiFiMAN EarPads have a vinyl rim which is very think , that causes severe itching after long sessions
I've never experienced the itching myself with my HE-400s, but OK. However, I would imagine that you could have the same problem with an oval shaped headphone that has that vinyl rim.
I can't say this with absolute certainty, but I believe that, all else being equal, the circular pads are going to have a greater internal volume (since they'll have to be larger in order to fit an ear) and thus will end up with a wider sound. At the very least, there will be more "air" to the sound.
I think there is some validity to this. The two broadest imaging dynamic cans are the K7XX and HD800, are also two of the biggest. Look at how Grado achieves its soundstage with various pad sizes. Planar / electrostats have always been HUGE, and generally they are not found to be closed in sounding.
