sigh, well its STARTING to make a bit more sense, but still im definitely not 100%. So what I want is I think to just have shared ground since thats simpler and it should be fine for single ended usage. I also do want to switch an LED indicator as well though, since it seems like it wouldn't be a ton of additional trouble. So, for shared ground WITHOUT the LEDs, I'd want a 3-position/deck, 3-pole switch (or 4 poles)? Whatabout for with LEDs, would I then want a 4-position, 3 pole switch? "Position" seems to be slightly confusing terminology, as to me that implies how many different selection options the switch would have. I'm still a bit confused also as to what each of the decks and poles corresponds to! Does L, R, and G, correspond to the 3 decks, or the 3 poles? If perse I wanted to switch some balanced sources instead, with separate grounds, you said then I'd use a 3-position, 4 pole switch, which leads me to believe that each of the "poles" corresponds to one phase of the signal (L+,R+,L-,R-) - or in my case simply just L+,R+, and G for a 3 pole switch? Is that correct? If that is correct, then why the 3 positions/decks, because 3 obviously wasnt just an arbitrary number....jees i feel like banging my head into a wall...hope this becomes clearer soon
