- Feb 17, 2010
I'm glad you are open to the possibility that there are exceptions, because there are:
All transistors have very wide gain (the order of 80-350). Even the Hfe gain band selected types. This does not tend to affect burn in much, but is the main resdon for their being a finite warm-up time in amplifiers. It also can change the amplifier's audio stability if the amp is driven hard, particularly into clipping, taking sometimes minutes to recover. Their bandwidth, input capacitance, Vbe (on voltage), and many other parameters vary wildly between samples and temperatures. This is why discrete audio design involves experience and knowledge.
Electrolytic capacitors are far from tight tollerance. The best available are 10% in terms or their capacitance, these are rarely used. +/-20 % is commonly considered high quailty, and low cost gear uses +80/-20% tollerance, which if used with abandon will result in very lose consistancy between unit. However a little known and certainly overlooked factor is that a key characteristic of theirs: ESR (Electrical Series Resistance), or how closerly they represent a low impedance at higher frequencies, changes over time. Now it is well known by professional electronic engineers that is goes up over time slowly, as the componant wears out. This is VERY slow, and generally you will only noticed the effect when you find someone whop can change these components out for new parts, say 20-40 years of use. (don't worry, the 1% capacitors that should be in you RIAA phono stage are different and super stable, if the designer knows anything.)
However, what is less common knowledge, is these same parts go through a rapid change of ESR over the first few 10s of hours after the unit is switched on. The ESR goes down as the electrolyte settles to its working voltage, which improves their performance. The change is quite significant, and I would not be surprised if some equipment it could be audible.
A competant audio designer needs to design out these factors as much as possible. However you can only attenuate the effect, and it often cost money to do so. So this can be why high end gear gets expensive, but consistantly good.
Belief is a wonderful thing, but in Sound Science it should give way to repeatable results and scientific measurement.
I'm not buying your explanation but that's fine, we are all entitled to our OPINIONS. What's funny is I don't remember people talking about burn in much back in say the 1970's. I guarantee component tolerances are made to a higher standard now especially very high-end audio equipment. I know Resistor tolerances are better today and power supplies and voltage regulation can be built to much better standards. Many times, parts are hand selected and matched. Again, as far as I know there is no widely accepted definitive scientific study that proves beyond a shadow of the doubt that burn-in is a real phenomenon that greatly improves the sound quality. Like I said before I'm guessing there are exceptions to this, I'm sure but again I can't prove anything!
