NoPants
- Aug 14, 2006
You're asking in the wrong place, the KGSSHV has undergone a fair amount of revisions. The eagle files are available online so anyone can do their own small run.
Hello,schematics here
http://gilmore.chem.northwestern.edu/kgsshvproduction.pdf
http://gilmore.chem.northwestern.edu/kgsshvps8e.pdf
on board heatsink version gerber files
http://gilmore.chem.northwestern.edu/kgsshvampv6.zip
off board heatsink version gerber files, latest board
http://gilmore.chem.northwestern.edu/kgsshvampv7s.zip
power supply
http://gilmore.chem.northwestern.edu/kgsshvps8e.zip
IXTP01N100DHello! What part you were using instead of 2SA1968 and 2SJ79, which is super hard to find?
Yes. Avoid these criminals.It's worth pointing out, that while that person's information seems reasonable, you should never implicitly trust what you read without verification, or commission a build from them. They take Kevin Gilmore's designs and absolutely butcher them. Google or Bing search for 'Kevin Gilmore Megatron Lil Knight Tran Thuan' to see what sort of horror story this person produces.
I could not comment on Little Knight 's personality as I did not know him well enough. Perhaps I am the lucky one. The information from the link is correct. I knew because I built one and my KGSSHV has been working for the past 5 years.It's worth pointing out, that while that person's information seems reasonable, you should never implicitly trust what you read without verification, or commission a build from them. They take Kevin Gilmore's designs and absolutely butcher them. Google or Bing search for 'Kevin Gilmore Megatron Lil Knight Tran Thuan' to see what sort of horror story this person produces.
