iRiver Problems
Jul 14, 2007 at 11:09 AM Thread Starter Post #1 of 11
Haykuro
I've just borrowed an iRiver H320 from someone and when I plug it into my computer it shows the charging screen. I heard that you need to hold down the play button in order for the iRiver to show up on the computer, but I'm not having any luck.
Please Help.
Jul 14, 2007 at 5:20 PM Post #3 of 11
if I'm not mistaken, doesn't the H3XX series have 2 usb ports?
are you sure you have teh cable plugged into the right port?
Jul 14, 2007 at 5:32 PM Post #4 of 11
Originally Posted by majkel /img/forum/go_quote.gif
Do you connect the player switched on or off? Try connecting the player to the PC when the player is turned on.
Yes, I also suggest plugging in after player is turned on. As for the two USB ports, you should be using the USB 2.0 Device port.
Jul 14, 2007 at 6:34 PM Post #5 of 11
If you continue to have problems you may want to reset the unit or reload the latest firmware.
I have had good luck calling Iriver tech support during non busy hours (ie early in the morning). They answer the phone after a 10-20 minute wait and you speak to a person who can actually help you.
Jul 14, 2007 at 8:07 PM Post #6 of 11
Thanks for all your help guys! I turned on the player first then plugged it in and it worked. I can enjoy this little beauty now
Jul 19, 2007 at 11:40 PM Post #9 of 11
Please Help.
www.misticriver.net
Read the forums.
Jul 20, 2007 at 12:07 AM Post #10 of 11
Here's a link to the owners manual.
