feverish
- Dec 29, 2003
Ya I see what you are both saying. The 20 mbps figure was a guesstimate as I have never heard of anyone going above 16 mbps. So 20 seemed like a liberal number.
Originally posted by Frenchman As for speed, no. 20mbps (usually lowercase b means bits, btw) is slower then crap. Even if you meant bytes, it's still crap. The current line of Toshiba 1.8in PCMCIA drives are quite fast, 100MBps to be somewhat precise. However, it is quite possible that they have reduced to speed to an acceptable level (20MBps perhaps) in an effort to reduce harddrive wear/tear and battery consumption. Originally these things were marketed as portable drives, and limiting speed helps keep your idiot iPod from running itself out of battery quickly. |
Originally posted by PYROTAK and the ipod DOES use firewire 1 right? |
