Originally posted by feverish
why would there be any difference between the two at all? Both of the cables' max speed far excedes what the iPod is capable of writing at. Unless the chip designed to handle the USB transfer wasn't as well made as the firewire chip. Just pondering |
The two technologies are
completely different. USB2.0 has a higher (and only theoretical) maximum
burst transfer rate, but for sustained bulk transfers, FireWire will almost always be faster, usually significantly faster. Plus if you have
any other devices connected to the same USB bus -- especially if any of those devices are USB1.1 devices -- you're going to see slower speeds, often significantly slower.
Originally posted by PYROTAK
yeah um what kind of crack have you been smokin.
[snip]
the only advantage that firewire has over usb is that it does not use the cpu to process rather it has its own controller |
Starting out your responses with remarks like "why kind of crack have you been smokin" only sounds clever when you actually know what you're talking about
Not only is FireWire processor independent, it also supports peer-to-peer transfers, has better device management, provides significantly better power capabilities, is more effective for bulk data transfers, better supports multiple devices on the same bus... etc., etc., etc. There's really no comparison. USB2.0's
only advantage is that because Intel licenses it for free, it's more widely available. The 480 vs. 400 comparison is little more than theoretical PR spec. In the real world, USB2.0 is slower than FireWire overall, and for things like bulk data transfers, it can't really come close. And that's compared to FireWire 400, which was around for years before USB2.0.
