RRod
- Aug 25, 2014
Does anyone know how to fix an ipod with bad sectors at the beginning of the sectors?
Have you tried using fsck?
I agree. Searching through this 200 page thread does not not help. Either we ought to have a sub forum with separate thread subjects OR a FAQ/ Wiki in the initial post that points to relevant posts.
Yes, both this thread and the ipod modding thread really could do with their own wiki or something, but...well I certainly can't be bothered to do the work! Plus, to be fair, things change all the time and I'm not entirely sure what the attitude of the rockbox and freemyipod people is to this thread/site as they do have their own sites after all. Just good that they post stuff here at all, really.
A guide to installing the dual-booter for the classic was posted on here a couple-of-dozen pages back somewhere. V8 I think was the most recent one. It works very well for me.
Rockboxing:
iPod Classic 5th Gen 60 Gig
[-=SNIP=-]
There is no such device. A 5th Gen (or 5.5) is an iPod Video. An iPod "Classic" is a 6th Gen or newer.
There is a world of difference between the 5.x and 6.x/7 gen iPods when it comes to modding and installing Rockbox. If you have a 5th Gen iPod Video (60GB makes it pretty certain that it's a 5th Gen, not 5.5 Gen), you're lucky to have an easier road ahead of you: Just use the Rockbox install utility to get things running, and you'll save yourself a lot of heartache.
If, however, you are trying to fix up an iPod 6.x/7 (a true Classic), you've come to the right place. There have been very promising recent developments, thanks to Rockbox developer Castor Munoz and others.
For iPod Classic owners: Our long Rockboxless iNightmare is almost over.
Pre-Rockbox Music/ Audio Extraction:
So I wanted to Pull all the old Music & Audio I had lying on the iPod. Based on my googling I found Sharepod & Yamipod both that are unable to read the iPod.
Was also getting this Disk has issues and needs to be scanned popup from Windows 8.1 - http://apple.stackexchange.com/questions/103265/using-windows-8-message-says-problem-with-this-drive
So, figured maybe updated it from 1.1.1 to 1.3 and that might fix the issue.
It hasn't as yet.
I suspect Sharepod and Yamipod leverage and need older version of iTunes somehow? Any thoughts on how I could pull the info from my iPod. The last used/ synced it was few years back with an older Win XP partition.
PS: I might have an older version of CopyTrans somewhere.
$replace($caps($left(%album artist%,1)),1,#,2,#,3,#,4,#,5,#,6,#,7,#,8,#,9,#,0,#)\$if($stricmp(%album artist%,Various Artists),%album artist%\%date% - %album%\%Tracknumber%. %artist% - %title%,$if(%album%,%artist%\%date% - %album%\%Tracknumber%. %title%,%artist% - %title%))
New USB driver was committed to git builds for the iPod 6G and Nano 2G. Should be a lot more stable/compatible then the old driver.
Just want to double check the system info after unzipping rockbox-ipod6g-20160803.zip. Under System | Rockbox Info I see: 0f89b04-160628 Is that correct?
After ejecting and detaching the device from my Win7 laptop and pressing Select to reboot, I saw the initial Rockbox screen, then got a black screen with an error (something like "No partition ... insert USB cable to fix it"). I forced a reboot with Select + Menu, and it came up OK.
I'm not sure where you got that file, but the build date is from June, so it's definitely not going to have stuff committed yesterday.
The new USB stack should hopefully fix problems like that.
I got rockbox-ipod6g-20160803.zip from here: http://www.rockbox.org/dl.cgi?bin=ipod6g
Could you elaborate on where to find the latest build, and any installation steps beyond just unzipping/overwriting... if any.
