Introducing VentureCraft SounDroid VALOQ [SDP-1]-Impression thread- Check second post for updates
Jan 10, 2016 at 1:00 PM Post #211 of 659
Jan 11, 2016 at 12:15 AM Post #214 of 659
AD8397 is here.
8-SOP type
AD8397 spec
Dual operational amplifier
Voltage feedback
Wide supply range from 3 V to 24 V
Rail-to-rail output
Output swing to within 0.5 V of supply rails High linear output current 310 mA peak into 32 Ω on ±12 V supplies while maintaining −80 dBc SFDR
Low noise
4.5 nV/√Hz voltage noise density at 100 kHz
1.5 pA/√Hz current noise density at 100 kHz
High speed
69 MHz bandwidth (G = 1, −3 dB)
53 V/μs slew rate (RLOAD = 25 Ω)
Jan 13, 2016 at 12:23 AM Post #215 of 659
I did it !
LT1469CS8-2 spec
Voltage 3V - 18V
Vos:30uV
Ios:13nA
Inv:300nVp-p
GBW:200MHz
SR:30V/us
Is:7mA(Max)
but after I changed it, 2.5mm out is very very noisy(Biggest white noise?)
3.5mm out is very clear... I don't know the cause.
I try once more lator.
Jan 13, 2016 at 8:16 PM Post #217 of 659
Jan 14, 2016 at 12:21 AM Post #220 of 659
  Guys, have you fixed that "white strap" issue with your VALOQ? Any information from VC on this?
Not yet, but I RMA mine back.
Jan 14, 2016 at 7:45 AM Post #221 of 659
FYI ,  I just replaced OP in Valoq from  Muses01 to LME49990MA*4 (Due to LME49900MA is single OP , so we need 2*2 in Valoq) . It gave me less hissing than Muses series and more natural sound . I would say it's worthy to try .
Jan 14, 2016 at 8:06 AM Post #222 of 659
I agree, as I have the same experience with the LME49860NA.
Jan 14, 2016 at 8:22 AM Post #223 of 659
Yes , Doctor ! I tried to follow your advice but LME49860NA is hard to find here :(  ; at least LME49990MA makes me happy without hissing now
Jan 14, 2016 at 8:29 AM Post #224 of 659
??  Just go to Mouser.com and they ship world wide.  But I am glad you liked it too.
