snatex
Does anyone here mess with the EQ in the iOS app when using the Cipher or BT cable?
For critical listening any album before buying, I am using LCD-XC or K1000.
About achieving the same results with any Cipher vs Analog, it is possible, but require a lot of patience and probably need to involve Reveal. Between CBT and Cv2 - the same, but EQ must be used along the way for further corrections.
I've made simple tests with iSine 20 and CBT / analog jack / Reveal some time ago:
There is a lot of room for personal experiments and improvements. Unfortunately, such matching procedure can be achieved flawlessly mostly on measurement equipment. Normal person must trust his own ears and make everything to "sound similar" by ear or based on external data.
I am afraid there is no chance to convert such complicated measurements into only 10 band fixed EQ. At least if the goal is to make straight tonal conversion from one model to another. You probably have to experiment yourself with the best settings that suit your taste.
Here is latest custom, 66 band, parametric EQ for LCD-i3 that makes their sound signature pretty much like 90% of LCD-i4:
Sounds best with i3 Cipher v2 and analog jack. For i3 Cipher BT I recommend using EQ v8 from my previous post.
The differences versus i4 will still be there, especially with overall quality, midrange position, highs timbre and lowest bass. Nevertheless, it is still very good LCD-i4 emulation with ~90% tonal similarity and about 70% quality of i4. What is more, with this you can actually at last use both Ciphers and Reveal properly with i3. I still cannot understand why Audeze just copy-pasted i4 DSP settings for i3 instead of making a proper ones from the start.
After applying such EQs, you should probably get the best chance to check and decide if LCD-i4 is a way to go for you and valid upgrade option. The only really better choice is to rent normal LCD-i4 for personal listening session.
I entered the 10 data points in Audeze HQ App from Harman 2019 IE into excel, then rounded them, calculated the slope between them, then entered the same points from AF's Cipher V2 measurements, added 5db to all of these to get the big 4k dip within striking distance of the EQ app, then applied the necessary EQ to match the slope of the Harman 2019 IE. The Cipher V2 EQ values are in the box. Let me know what you think.
Thanks for this - sounds GREAT to me. The i3s always sounded a bit "tubby" and muffled with the default Cipher v2 EQ, but this sounds really nice: bass is balanced, mid-range no longer congested, treble airy![]()
Peaking | 31 Hz | 1.41 | 0 dB |
Peaking | 62 Hz | 1.41 | 0 dB |
Peaking | 125 Hz | 1.41 | 0 dB |
Peaking | 250 Hz | 1.41 | -3 dB |
Peaking | 500 Hz | 1.41 | -3 dB |
Peaking | 1000 Hz | 1.41 | -6 dB |
Peaking | 2000 Hz | 1.41 | -2 dB |
Peaking | 4000 Hz | 1.41 | 4 dB |
Peaking | 8000 Hz | 1.41 | 4 dB |
Peaking | 16000 Hz | 1.41 | 1 dB |
Stay updated on Audeze at their sponsor profile on Head-Fi.
