Hello. I found that bass is quite lees punch and poor compared to ibasso dx220max, is it possible because the battery is weak now?
Introducing the Astell&Kern A&ultima SP2000T
- Thread starter JasonNYC
- Tags
- a&ultima astell&kern dap sp2000t
Ibasso DX220 has more output power, better driving hp/iem.Hello. I found that bass is quite lees punch and poor compared to ibasso dx220max, is it possible because the battery is weak now?
But that doesnt meant that sp2000t, not able to drive Odyssey.Ibasso DX220 has more output power, better driving hp/iem.
olddude
It drives my Odin quite nicely. Through I prefer my SP1K for that IEM.
Anyone else with the SP2kT facing issues with a sluggish/slow OS? I definitely feel like the screen should support a refresh rate of 60hz but it legit has a very noticeable delay when I try to perform any basic functions.
YCHANGE
- Apr 26, 2017
I'm trying to install Roon Arc Version 1.0.52 on my 2000T.
When I try to install, I keep getting the message:
Parse error "There was a problem parsing the package"
Any help appreciated
Roon Arc is currently not whitelisted for the SP2000T, therefore not supported at this time. It shows on the download list as it whitelisted for other players. Don't have a timeframe on if or when the SP2000T will be whitelisted for Roon Arc.I'm trying to install Roon Arc Version 1.0.52 on my 2000T.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
jamato8
No word from Room about it?Roon Arc is currently not whitelisted for the SP2000T, therefore not supported at this time. It shows on the download list as it whitelisted for other players. Don't have a timeframe on if or when the SP2000T will be whitelisted for Roon Arc.
rlw6534
It's likely not Roon that's holding this up. Roon Arc should work fine if the SP2000T uses Android 9 as stated. It's the never-ending whitelist issue that seems to take forever... I'd love to see Apple Classical on my SP1000M, but nope, not on the whitelist... even though it's compatible with Android 6.
chef8489
- Jul 1, 2005
@JasonNYC My sp2000t looses the sd card and library every time I turn it off. I have reformatted the player multiple times with same problem each time..
I am using a Sandusky 1.5tb I purchased straight from western Digital. Player is only 8 months old.
chef8489
- Jul 1, 2005
Card works fine in tablets or hooked up to pc.Might be the card.
olddude
Are you letting it reformat from the AK or external?
chef8489
- Jul 1, 2005
It is being formatted in the akAre you letting it reformat from the AK or external?
mrcatbling
sorry im like months late, but the concern I have with sdcard in ak rn is that I like putting songs in my favorite tab but whenever I remove the sdcard everything just gets deleted and I lose all of the songs I have saved thereIt is being formatted in the ak
