how is the soundstage, imaging and layering for gaming?In that price range. If you can handle the deep fit and some tip rollings to cater the upper mids. This set is one of the best technicalities within its price range.
Introducing Shanling SONO - Budget Triple-Driver Hybrid Earphones
- Thread starter Shanling
- Tags
- shanling shanling soho
Soundstage feels diffused and imaging is precise. Didn't try on gaminghow is the soundstage, imaging and layering for gaming?
Hello,
I have been listening to my new Sono, and I think they are very good, with lote to give.
It's a surprise for me...I will be posting my fellings in the next days.
drumtones
narrow bore tips help tame the BA glareJust received and had a quick impression.
Bass is above average texture and slam.
Mid is on the thinner side
Upper mids has glare
Air seems ok
I think this needs tip rolling.
ThEvil0nE
- Mar 30, 2010
Do you have the SednaEarfit and SednaEarfit Light? If so, how are they with the Sono?Just received and had a quick impression.
Air seems ok
The attachments included in the kit are poorly adapted; So far I have used the SpinFit CP360 - they are the ones that remain in the sound guide. The sound on the balanced cable is more or less acceptable. But the way they reproduce instrument-rich music - especially in rock compositions - is infuriating. Electronic music has a normal sound. Source - Fiio btr7 and shanling m0 pro. All music is in high resolution (32-384, DSD 128). Conclusion: Headphones are on par - HiBy Beans or TRN. Fiio FD3 and FiiO FH3 sound better and more interesting. Just my point of view!
dbsylvia
Shanling Sono is an interesting listen that has its moments of fun. Here's a link to my review.
I take back my words (except for the attachments included in the kit - they did not suit me at all), I found several Sony attachments from old headphones, their shape is very similar to DUNU S&S (Stage & Studio) - the hiss disappeared (the driver of the armature no longer sticks out on complex compositions ). Conclusion - it is necessary to select liners. I'll keep the headphones, the SHANLING team is great, well done.The attachments included in the kit are poorly adapted; So far I have used the SpinFit CP360 - they are the ones that remain in the sound guide. The sound on the balanced cable is more or less acceptable. But the way they reproduce instrument-rich music - especially in rock compositions - is infuriating. Electronic music has a normal sound. Source - Fiio btr7 and shanling m0 pro. All music is in high resolution (32-384, DSD 128). Conclusion: Headphones are on par - HiBy Beans or TRN. Fiio FD3 and FiiO FH3 sound better and more interesting. Just my point of view!
Arrived DUNU S&S (Stage & Studio), size L was suitable for me, but there is a big problem - they greatly lift up the high frequencies and slightly distort female vocals. But the stage becomes wider, and bass instruments sound more realistic. My choice is simple ear pads, here I will clarify not from Sony, but from SoundMAGIC E10, with them there is a clear V but there are no obvious distortions in the sound of instruments or vocals. DUNU has a nozzle diameter of 3.77mm, SoundMAGIC has 5.1mm. And most importantly, they do not block the compensation hole. Nozzle with black 0 ring. Also tempered are MoonDrop Spring Tips Acoustic, they are similar in size to SoundMAGIC.
Shanling Sono Now Available in Metal Blue Color!
Our budget-oriented triple-driver earphone with a fresh new look.
Now Available on Shanling official E-Shop
https://store.shanling.com/SONO-pd783509788.htm
Buy now to enjoy extra 12% discount, just 69.50 USD
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
ginger2017
I personally couldn't find the wright tips for my ears, so i gave them away for free to a good friend with the wright ear canals.
I'm gonna search for something that soothes me better.
