Thanks for response. I suppose, It will cause double amping.
Introducing Shanling M30 - Modular Desktop Hi-Fi Streaming Player
- Thread starter Shanling
- Tags
- shanling shanling m30
Kiats
I believe that was discussed previously. I recall that it will not.Thanks for response. I suppose, It will cause double amping.
The RCA/XLR outputs are using different circuit than the headphone amp, so we do not consider it to be double amping.
If you want the "simplest" output, run it in Bypass mode, then it's simple AK4497 into Muse8920 on output, with volume controlled by DAC itself(So set it to 100% for line-out).
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
I'm trying to make local update from 1.22 to 1.24 but I receive error message (without any code or info) every single time. OTA update has never been worked. I don't ask why. Can you please check an confirm that it's known issue or individual? @Shanling
We are not seeing such reports.I'm trying to make local update from 1.22 to 1.24 but I receive error message (without any code or info) every single time. OTA update has never been worked. I don't ask why. Can you please check an confirm that it's known issue or individual? @Shanling
Can you please send me PM or email to info@shanling.com? Will see what could it be on your unit.
Firmware Update for M30 Modular Streamer
Bringing in the updates from EM5/EA, like the new source switching. Please be sure to factory reset M30 after firmware and check the guide for navigation the new system UI.
Full notes and download link: https://en.shanling.com/article-M30V128.html
Kiats
Thanks @Shanling . Your team seems to have improved the capacity for the OTA servers. It was very quick today. All installed and did a system reset and set up the M30 again. Wireless projection seems to be working well with my android devices nicely. Enjoying with the MySphere 3.2 on turbo gain and tube output.Firmware Update for M30 Modular Streamer
Kiats
Rainy Saturday morning in Singapore. Nice start to the weekend with the new UI on the M30. Streaming QQMusic into the KGSSHV Carbon/Stax SR 407. This is the wireless projection on my iPad. You will notice the volume button on the left: android devices will not have that because you can control the volume by the volume wheel of the android device. This is the workaround for iDevices. @Shanling credit to the team for this workaround.
Kiats
Just to show what the android device UI looks like in Eddict Player (this is off my DX300):
Kiats
Yes, currently M30 has only pre-amp function, where you are able to adjust volume on M30.
Fixed Line Out mode might be added with future firmware udpate.
@bigbeans had raised the question about pre-amp as a line out, to set the context of @Shanling ’s reply above.
Well, the fixed volume LO mode has been added. Kudos to the team @Shanling !
Kiats
@Shanling if I am not mistaken the display frame for what is currently playing used to be smaller? Good job! I was playing around with Apple Music and was wondering why it looks so much more pleasing to the eye. Before it just hit me.
werewolff9
any ideas when new dac and player modules will be released??
Kiats
@Shanling Quick Q: what is the difference between “bypass“ in SRC and SRC being switched off? Thanks!
It's the same. In swipe down menu you turn it on/off, inside the settings you switch it to bypass.
Kiats
Thanks for your reply. I figured as much. Cos it seemed to have the same effect and sounded the same to me. But just wanted to be sure.It's the same. In swipe down menu you turn it on/off, inside the settings you switch it to bypass.
