ipaddy
human bean
I know I can review the specs myself to compare, but in the "real world" how does this compare to the M1 Plus?
There will be the possibility to remote it wireless from our phone like there is in fiio m23?
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Cell phone fix shop would replace battery in DAP with easy. I have rescued R6 OG SS replacing battery for cheap.Is the battery replaceable by user? If not, why not? It's a shame that a device that can be useful for many, many years is junk when the LiPoly battery is done.
A bit of sound upgrade, a big change to overall use approach.
We have a simple SyncLink feature in our app that can be used for remote controlling of MicroSD card playback.
But since this is Android, you can get apps to do even full screen mirroring.
Yeah ! Another good question but no answers.I would like to know if the M3 plus is still having a warm sound signature or not, like UA6 or M1 plus.
(USA Pricing might differ)!!!
@Shanling I would like to know if the M3 plus is still having a warm sound signature or not, like UA6 or M1 plus.
Hi! I'm sorry, I really don't want to be annoying, but... Should I be anticipating the answer to my question, or it would be better for me to just move on?
What is the big change? If it's only a it of sound upgrade, then no point in getting if have M1 plus?A bit of sound upgrade, a big change to overall use approach.
It's full-on Android system compared to simple Linux system.What is the big change? If it's only a it of sound upgrade, then no point in getting if have M1 plus?
M3 Plus is smaller, with better Android and slightly higher power.How does this compare to the M6 Ultra?
Similar to modern smartphones, but easier to replace as we using overall a bit simpler and less glued construction.
yes, it still follows our a slightly warmer tuning.
Sorry, can't comment on the H-Mode, not info we would have available.
