I made the firmware update but i didn't listen to the paw gold yet ,are there any diferences in sound signature?
Introducing Lotoo PAW Gold
- Thread starter audionewbi
- Tags
- lotoo-paw-gold lotoo
spitfire777
- Jul 8, 2013
Have just ordered made to measure case for LPG with choice of colour and leather for $49 at AliExpress.
spitfire777
- Jul 8, 2013
decided to cancel order - not sure about aliexpress
dulty
- Apr 28, 2014
If it was this one, I already got one, they are legit:
http://www.aliexpress.com/item/E4-EASECASE-Custom-Made-Genuine-Leather-case-for-LOTOO-Paw-Gold/32307710856.html?spm=2114.01010208.3.2.TwGmmQ&ws_ab_test=searchweb201556_6,searchweb201602_4_10036_10035_10034_507_10020_10001_10002_10017_10010_10005_10011_10006_10003_10021_10004_10022_10009_10008_10018_10019,searchweb201603_6&btsid=486169ae-3d59-4074-8bc9-f4277f2fd13d
rx79ez08
- Aug 18, 2010
Use the Chinese version 5.0.1.10. www.lotoo.cn/page/Default.asp?pageID=20
PSA.
Do not update to 5.0.1.10, especially if you use CUE files. On my unit that version seem to fail at reading CUE files, and in one case it even causes the unit to lock up requiring a hard reset.
I have since downgraded to 5.0.1.9, which work correctly for the same files.
spitfire777
- Jul 8, 2013
Does anyone know where I can get a case for the LPG not through Aliexpress. Had difficulty putting payment through to them.
Cheers Thanks
Cheers Thanks
psawjack
- Aug 28, 2015
Cheers Thanks
I've brought this up on here before with unfavorable results. If you happen to find a retailer feel free to let the rest of us know.
Thanks
spitfire777
- Jul 8, 2013
Aliexpress seems to be the way to get one but they dont take paypal even though it shows they do and i am having a real problem putting payment through to them. on their website it states its going through then says it fails and you have to do the same thing again. 5 times this happened. also the website shows a design your own case with lovely colours and textures of leather to choose but this is disabled also. So i have wasted about 5 hours on this sxxxxxxxxt
Jazzi
- Feb 28, 2015
I wish I could help. I have the Dignis case, and I like it a lot, but they're impossible to find now. A few weeks ago Dulty contacted Dignis directly and was told they weren't selling them anymore. Have you tried Taobao? Seems they have a few. Not the easiest way to order, but I've had success buying there in the past.
spitfire777
- Jul 8, 2013
Many thanks jazzi. At the moment the lpg has just been delivered to me and i cant put it down. I think i might just wrap it in kidgloves its so beautiful.
dulty
- Apr 28, 2014
LOL I know what you mean @spitfire777 it's so nice without the case, if you trust yourself, just use it as is. Check this out:
That's a Pelican 1010 (thank you Noble), almost perfect fit with the case on, without the case the length is perfect, needs a thin layer of foam on the top or bottom to stop it moving about. Even without the addition of the foam I don't think there's any chance of damage, it doesn't move about too much.
So you can try no case during use and mega safe Peli for transport.
- Oct 6, 2013
How do you like that A6 Easecase? I'm afraid that's the only solution we have now
spitfire777
- Jul 8, 2013
The noble case is brilliant. I am using my k10u case fits like a glove. Thank you dulty. No need for a leather case now so chuffed with the otter box from noble. Just down loaded latest firmware and am buzzing with excitement. Shows so much more authority than the qp1r which is an excellent player. One song did it for me as the decider which is senses working over time by XTC. To hear the deep base and the drumming on this song is amazing. Anyway back to work with my golden brick.
- Oct 6, 2013
I few more alternative carry case solutions were mentioned here: http://www.head-fi.org/t/744346/introducing-lotoo-paw-gold/1350#post_12074914 and http://www.head-fi.org/t/744346/introducing-lotoo-paw-gold/1350#post_12079411
spitfire777
- Jul 8, 2013
Bliss
