AbdullaSaleh
- Feb 5, 2016
what's your fav. dap and ciem ?
I will bet on 435 and LPG.what's your fav. dap and ciem ?
I think I ordered the right dap ,Thanks for your help guys .
Chaps, I have a silly Q: how do you creste playlists on the LPG? I searched the thread and found discussions on importing but not quite in how to add to the 3 playlists... Apologies if this has been dealt with before but I don't seem to be able to track it down.
Kiats, I do not think that there is any way to load or save a playlist between your computer and the LPG. They are local Lists only.
To add to List 1, 2 or 3, you right-click on the wheel while in the File Browser. So depending on where your cursor is, you could be adding a single song, an album, or (in my case) even a folder containing an entire genre.
You will then see the songs within the List in the List view. There you can delete or reorder the List songs (or clear the entire List at the upper level view). Everything is done by right-clicking.
I suspect that you may know all of this though. Cheers!
Kiats, I should add that once you start playing a Playlist, you can add songs to it on the fly from the file browser. This means that the PAW Gold has a Rockbox-like "Dynamic Playlist" function.
I find this feature very useful. What do I want to listen to next? I cue it up.
(Actually I would love it if the LPG had the Rockbox choices of "Play Next" and "Play Last". Currently it is always Play Last, i.e. it adds the song to the end of the Playlist. But you can then reorder songs from within the Playlist if you want to.)
I have only an issue is that if you add anything to your card and update the database, the playlist is messed up.Kiats, I should add that once you start playing a Playlist, you can add songs to it on the fly from the file browser. This means that the PAW Gold has a Rockbox-like "Dynamic Playlist" function.
That is interesting. I do not think that I have ever tried that - my Playlists are really temporary - but it makes sense that it could screw up. The playlist is referring back to the database but the database has changed.
Hello All:
Does anyone have a copy of the latest update? Does it come with any differences in Sound Quality?
