Scott_Tarlow
- Apr 13, 2009
Does this work with UE extruding cable connectors like on their customs?
can you post the pictures with someone using it ?
How does this product work? Is it a built in amp or just a wireless cable. Would it work with Campfire Audio IEMS?
Same here. Maybe they mean something like the sony muc-m2bt1:
@lear-hk : just to make sure I understood it correctly, no apt-X codec support and 3hr battery life?
Just simply exchange this with your original cable, then, you would enjoy the wireless connection and the benefit from the BTC-01.
Yes, it will work with your Campfire IEMs.
can you make the pin for JH Siren Series CIEM ?
Is there a Mic for calls as well? It looks like there is..
