lear-hk
Sponsor: LEAR
- Jan 18, 2013
The wireless range of LEAR BTC 01 Bluetooth cable !
LEAR BTC-01 Bluetooth cable quick start guide!
Embrace the Bluetooth revolution! Introducing our first high quality Bluetooth "Wireless" cable specially designed for earphones with detachable cable design at just HKD$499(USD$65) up!!!
Just connect the BTC-01 to switchable cable earphones to enjoy a high-end Bluetooth technology.
Key features of the BTC-01:
1)Balanced output,usually seen on high grade players such as AK, Onkyo , Cowon etc.
The design of balanced output can help to reduce the crosstalk and improve the clarity of the sound.
2)Internal Class AB balanced amplifier stage, the output is over 30mW@15ohm, even better than a lot of smartphones phone out in the market.
When comparing to some of the similar products, the output is at least one time stronger!
3)Built in Lithium polymer rechargeable batteries, when charged around 50mins, can have over 3 hours of play time. And it also supports playing music and charging at the same time, when you have portable charger with you, you can extend the using time.
4)The use of high quality OFC pure copper cable can improve the transmission efficiency and durability. Comparing to similar products, the number of wires is at least one times more.
5)We've chosen high quality capacitors from Murata Japan, making sure the quality is on point and stable.
6)We have different kind of version in order to fit with all different kinds of plugs!
7)Built in high sensitivity microphone to make sure your calls are loud and clear.
8) Bluetooth 4.0 standard
9)Connects two device at the same time
10)Supports PC/Mac and both Android and iOS
BTC-01 retail prices:
USD$65 (CM/MMCX Plug)
USD$91 (IM/IE/UE TF Series)
USD$103 (FitEar plug and other special requested plugs)
Order your BTC-01 today via:http://goo.gl/0keaDg
