After much unnecessary delay on my country post I finally get the sora light 2019 edition
OOTB I plug in the iem with applied M+ (I think) tips and the feeling is not good. This could be driver flex and immediately I notice right iem didn't produce sound, until I crank up the volume. Then I also realize that reposition the iem slightly will change the sound (moving jaw etc). So far in place with the previous reports here in the thread.
Move to next smaller tips. This time better in term of placement but still shallow insertion to avoid driver flex.
Then I settle on Newbee medium foam and write this while still listening to them on my desktop dac.
This is just an
impression so it might change in the future.
After reading some last comment regarding sibilance I lined up my problematic list of track and start listening. To my surprise they do sound bright and metallic at times but not sibilance in conjunction of typical 8khz peak. Many track that I associate with sibilant in recording does not sound so with sora. Instead they sound bearable and felt intentional in recording. However on some track that usually not a problem with my other iem / earbud do sound rather unneccasy bright. Also on my track and setup its not the SSS.. thats problematic but TTT.. and CCC..
But of course this just the extreme of track. Most of the time with average track there's not immediate problem and can be rewarding with finely recorded track.
Mid is just right not too laid back not too forward. Stage is slight above average in this price point and center depth while not impressive not that bad either. I felt the vocal mostly outside my skull and never inside like some KZ
Bass is enough / light but will come in when called. I felt the mid bass slightly lacking and not that fast. Even my yincrow rw-9 earbud with even lighter bass have faster mid bass. Good news is that it's never muddy even with foam tips.
Will continue listening / burning / tips rolling and maybe i will put my full impression later.
Does it worth importing from Japan? Not much I say. Unless you're already visiting Japan or have someone visiting pick it up for you. It no more impressive nor less problematic that tin audio t2 at the (current) same price range IMO. But the perceived resolution IS better that T2 in case someone wondering.
Cheers.
