RikudouGoku
Member of the Trade: RikuBuds
How is it? Compared to chi-fi offerings and to Intime´s other iems if you got them?I have this one
Got the Sora 2, but lacking a lot of bass for me. So I got the GO and was very dissapointed by it, sounded like a regular chi-fi iem with bloated bass....I have other intime as well , the sora midnight , sora antique , sora light , sora light 2019 , sora 2. The sho is an audiophile basshead.id you want to hear the start with sora 2019 and sora 2
Sora 2 is definitely light bass ,the sora light has bass and the sho is the best in bass wise from intime , also forgot about the ti3 which is better bass then sora light 2019Got the Sora 2, but lacking a lot of bass for me. So I got the GO and was very dissapointed by it, sounded like a regular chi-fi iem with bloated bass....
Graph wise, the Sora 1 and Sora Light looks great to me.
This is based on your comparison between Ti3 or Nagi? Is the bass of Sho DD simillar in quality to Sora2 but extended?Sho DD
TOTALLY! Have you heard Ti3 and Sho DD? Is it still better than these two?Nagi bass rules. Period. (and I'm not a bass guy)
You can check the FR. Ti3 got more bass quantity AFAIK, quality not sure.This is based on your comparison between Ti3 or Nagi? Is the bass of Sho DD simillar in quality to Sora2 but extended?
Check the reviewsAny comparisons between the Nagi and Sora, Sora 2 and Sora Light?
I like the Kira but just hoping there is bit more warmth
I can only compare Sora2, Nagi and Kira.Any comparisons between the Nagi and Sora, Sora 2 and Sora Light?
I see, thanks for the comparison, then it does seem there is no real need for me to get the Nagi too, since it doesn't differ too much from Sora 2.I can only compare Sora2, Nagi and Kira.
Nagi :
Bass - Controlled and accurate.
Mids & treble - Pretty much the same throughout Intime with Kira being the brightest, Sora2 and Nagi pretty much the same audibly. Sora2 and Nagi having a fuller bodied sound compared to Kira.
Technicality - Adequate soundstage and layering. Better than Sora2 maybe on par with Kira.
Kira :
Bass - Lacks sub-bass, only starts to rise around mid bass.
Mids & treble - The brightest among the 3. Less full bodied compared to Nagi & Sora2.
Technicality - Adequate soundstage and layering. Better than Sora2 seems like on par with Nagi.
Sora 2 :
Bass - Boomy. Kick drum sounds accurate but bassline not so much.
Mids & treble - Sora2 and Nagi pretty much the same audibly. Sora2 and Nagi having a fuller bodied sound compared to Kira.
Technicality - Smaller/intimate soundstage. Layering is adequate but can get little crowded on bright, multi-instruments track.
There is substantial difference. I didn't do much justice with my comparison but though the mids and high sounds the same from my impression but the bass quality in Nagi is on another level above of Sora 2. And even if soundstage is not your thing (it's an IEM anyway, better soundstage could be achieved from headphones), the sound layering on Nagi is better than Sora 2. I could still consider Kira and Nagi to be a side-grade, depends on your sound preference but Sora 2 and Nagi is definately and upgrade.I see, thanks for the comparison, then it does seem there is no real need for me to get the Nagi too, since it doesn't differ too much from Sora 2.
