soundblast75
- Nov 30, 2012
I'm with you, this is real
Yes, it is UNIQUE!P6 Pro has arrived and listening now!
So far I'm stunned with how pleasant it sounds. Extremely forgiving sound that maintains insane technical ability with some of the best texture I've heard to date. Will post proper impressions soon!
May I know what card you are using? I have previously encountered similar issue with Lexar card on my P6 and it resolved after changing it to SanDisk Extreme Pro.So while I love the sound, I’ve been having an issue with the P6 Pro. Every time I go to directory - internal storage - open my folder, the screen just blacks out and nothing happens for a little while. I then have to click on the screen several times and press the power button to “wake it up” again
I’ve tried rescanning my library several times but it is not working either, and it is not recognizing the files on my SD card either. Anyone have any fixes for either of those issues?
Edit: I think the DAP actually restarts itself every time I try to access that folder
Isn’t the C9 just an Amp?In general, how‘s everyone’s experience on the UI and OS stability of P6 Pro? I’m contemplating between this, the upcoming M30 or C9.
There are differences between P6Pro and LP6. One is discrete and one is IC based. The reason why owning Both is Good!!! LolCorrect, I want the C9 for the tube, same as M30 and I can stack C9 with R8. As for P6 Pro, I’m attracted to the R2R DAC![]()
The UI is simple, easy to learn, not in the way. OI other than issues with SD cards I had issues only with Kingston, no other stability issues. It has been stable. Sound is really full and detailed. For balanced drivers it is the best I have heard. Like M8 better with dynamic drivers. Just crossed 300 hours tonight.In general, how‘s everyone’s experience on the UI and OS stability of P6 Pro? I’m contemplating between this, the upcoming M30 or C9.
The
Hi Alex @twister6 can P6 Pro play at least DSD256?
