mungster
Yep.Do know you have to find the FW appropriate to the right model, eg P6Pro and P6Pro Ti will have different FW
Yep. I meant they have updates for both models.Do know you have to find the FW appropriate to the right model, eg P6Pro and P6Pro Ti will have different FW
Yep. I meant they have updates for both models.![]()
The FW for LP6 Gold is up on the japanese site: https://drive.google.com/drive/folders/1eJwVuOkDtgBTiRyfG6ZdHofLn6k0JXSrFW 1.0.1.3 impression: Testing out the new FW on my P6 pro (grey), the bass note has stronger body, vocal slightly more intimate. I wait for LP6 Gold to be shared, as I can't find that one yet.
I notice a bug: The screen flickers now that I run my fingers across the screen, I'm sure LP will fix that.
1.Dont copy in music directory, put it in the internal storage, no folder. Make sure to unzip first.For some reason, none of the firmware updates will work for me. It is just copying the firmware into my music directory....I have never had this problem before...can anyone help?
Try removing your microSD card, see if that changes anything? Maybe restart your mac? I'm not a mac user, I would have loved to try it on my end.I’ve done this before so many times but this time for whatever reason when I plug my P6pro into my MacBook Air I only get a music drive. I have no where else to put the file…![]()
Yeah I have tried it all, nothing works. I suppose no update for me.Try removing your microSD card, see if that changes anything? Maybe restart your mac? I'm not a mac user, I would have loved to try it on my end.
Hold the power button until it restarts.So I was able to get the p6pro to allow the newest firmware update but once I selected yes, it will not restart and now will not turn back on....Any ideas what I should do?
@audionewbi @Kiats
You would think this would work, but I held it for 5min straight and nothing...full battery. This is the most frustrating FW upgrade in my entire audiophile lifetime.Hold the power button until it restarts.
