pinkfloyd4ever
Do I want a higher value for R4 to lower the gain? Is there a formula I can use to find the gain with different R values?
the original design calls for a high brightness LED Circuit Explanation / Part Recommendations read the note all the way at the bottom. Not sure why he didn't just spec a lower value resistor and use a normal LED, but anyway, that's prob the reason it's so dim
Originally Posted by error401 /img/forum/go_quote.gif [*]The gain of 10 in the default BOM seems much too high to me, but it may be largely due to the reversed pot wiring. For low impedance phones, change R4 for a lower gain. |
Originally Posted by error401 /img/forum/go_quote.gif [*]The LED current with the recommended 10K resistor seemed much too low at my 18V power supply. I swapped it for a 3.32K and it's still quite dim with the LED I used. |
