OceanRanger
Have you been happy with the improvements and performance of the Zenith?I was using a desktop computer I built for gaming
Yeah, I defintely have been. My desktop was super noisey, in terms of USB interferance. I got the PhoenixUSB first, and that helped out a ton. I was so happy with the PhoenixUSB, I bought the Zenith Mk3. The jump from the PhoenixUSB to the Zenith MK3 was less than the jump from solo PC to PhoenixUSB and PC though. I don't regret either purchase. I'll probably buy the PhoenixNET at some point to complete the trinity.Have you been happy with the improvements and performance of the Zenith?
When you do keep us updated.Yeah, I defintely have been. My desktop was super noisey, in terms of USB interferance. I got the PhoenixUSB first, and that helped out a ton. I was so happy with the PhoenixUSB, I bought the Zenith Mk3. The jump from the PhoenixUSB to the Zenith MK3 was less than the jump from solo PC to PhoenixUSB and PC though. I don't regret either purchase. I'll probably buy the PhoenixNET at some point to complete the trinity.
Let me take a stab at this one. As I understand it, there are a few benefits of the Phoenix. First, it is a low-noise switch. Most consumer grade Ethernet switches have noisy power supplies and chips that can increase noise for those of us that are using them in our digital audio chains. The Phoenix addresses this issue. Second, sending music digitally, for example over Ethernet or USB cables can cause an issue known as jitter. Jitter is inaccuracies in the timing associated with samples of the digital data. Timing inaccuracy can cause issues as digital signals are being translated into analog signals for playback. I believe that both switch noise and jitter are real issues, though the topics are debated. The Phoenix has low a noise chip, low noise power supply, isolation and a very accurate internal clock that works to fix these issues. It is a high quality network switch so the only input/output connections (for data) on the device are Ethernet (RJ45).Kind of an odd question: I usually see people use a PC or a laptop or a server as their source. Can the Phoenix take just a portable hard drive or a DAP as its input? Thank you!
ahhh, thanks for clarifying @Roasty ! @bhschap my apologies for heading off on the wrong product. doh.@OceanRanger
I think he may have been referring to the phoenix usb reclocker and not the phoenixnet ethernet switch.
@bhschap
It will take the dap as input.
hooking up a portable drive as input may work if the drive is also connected to another machine with a music player calling the shots. Have not tried it tho..
I greatly appreciate both of your input.@OceanRanger
@bhschap
I'm with you. I've been looking at upgrading from my MacBook. I added a low-noise switch and did notice some improvements, but nothing like what I've heard with the Innuos servers. I too don't need a ripper. If it is just the server for which you are looking, the Antipodes CX might be an option. It is a low noise server. Antipodes does a pretty good job at splitting out server functionality from rendering functionality with SW. That said, even though I don't need the ripper, I have been more impressed by Innous' solutions than the others. I see a Zenith in my future.I greatly appreciate both of your input.
I am currently using a DAP --> Amber 3 DAC --> Cary SLP 98 preamp --> Cary CAD805AE Monos and was originally looking for an upgrade on the source side. I had my eye on something like Innuos Zen MK3 or Auralic Aries G1. I honestly just wanted an upgrade to the server. I didn't really care for a streamer or a ripper. I ran into the Phoenix and was curious if this could do the job, but better.
Anyways, any recommendations? Thanks again!
I have an AudiophileStyle.com special AfterDark 10mhz OCXO squarewave clock 75ohm version on order for my Etherregen. I use a Paul Hynes SR4T to power my ER and that provided a noticeable uptick in SQ, so I ordered another SR4T to power the clock. I use Ghent Audio Gotham DC power cords for the ER and ordered another one for the clock. Yeah, I know that I'm going down a rabbit hole.... but it's fun.Yea actually I do agree. The price they're asking for it is quite hard to swallow. I'm currently using an Uptone ER + AfterDark 10mhz clock and I think it is already pretty damn good.
@Roasty great post. Thank you. Are you using the NUC as a server and a player?I had a bit of free time yesterday.
Tried two setups:
1. Wall outlet, Intel NUC running Roon ROCK, USB, Rockna, Apollon power amp, Susvara
2. Usual setup with all the bells and whistles ie power conditioner, fancy cables and switches, fiber optic line, ER, SOtM, Innuos Phoenix, su6 ddc, to Rockna, Apollon amp, Susvara
Geez it is not a subtle difference.. The amount of treble energy, harshness and glare with the plain vanilla setup is immediately apparent. Next thing to hit is the relative lack of bass punch. And then when the music gets more complex, it sounds very congested and messy/rowdy.
Probably a sum of all the parts in the chain rather than just the Phoenix, but overall it's a realization that the "front end" before the dac really does contribute something to the final sound you get.
