you measurement chasers are talking way out of your scientific depth …
Oh dear, here we go again, some deluded audiophile using hypocrisy as the basis for an argument. Namely, we’re supposedly out of our “scientific depth”, while you demonstrate a lack of understanding of even the absolute basics! The first absolute basic is that digital audio is a measurement (or more precisely a series of measurements), so you’re accusing us of being “chasers” of digital audio, how’s that a bad thing? It’s certainly a lot better than chasing BS or just inventing BS yourself and then posting a bunch of nonsense based on ignorance! For example:
the reason why something like a REW cant measure music is because our ears act as " harmonic analyzers" and unlike a REW which can only analyze one or 2 or 10 sine waves at a time, real life sounds are made of countably infinite sine waves.
Firstly, our ears are relatively limited, non-linear harmonic analysers, while REW is a frequency analyser and it will only measure ”one, 2 or 10 sine waves at a time“ if the signal you give it only contains “one, 2 or 10 sine waves”. If the signal contains far more, then REW will measure far more. Clearly you don’t know what REW does or what it can measure, despite posted screenshots demonstrating measurements of far more than just 10 sine waves/frequency bands.
Secondly, of course real life sounds cannot be and are not made of infinite sine waves. If this nonsense assertion were true, real sounds would require an infinite amount of acoustic energy and break the laws of physics/science!
The SCIENCE behind it can explained as an incoming sound can be represented as a sum of certain sine waves( you can also split a complex music wave into a lot of individual sine waves via a mathematical operation called a fourier transform) , then the corresponding points on the basilar membrane will vibrate and that will be translated into a stimulus sent to the brain along with all phase distortions and stuff.
Classic, you put the word “
SCIENCE” in caps and bold and then completely misrepresent it and contradict yourself. Firstly, sure, sound waves can be split into it’s constituent sine waves/frequencies “
via a mathematical operation called a Fourier transform”, but according to you, this isn’t actually possible because real sounds contain “infinite sine waves” and would therefore take an infinite amount of time to calculate this “mathematical operation”. Secondly, given the topic of this thread, please explain how a simple wire/cable is performing this mathematical operation (Fourier transform)? And lastly, if a real sound contains infinite sine waves and there are “
corresponding points on the basilar membrane”, the basilar membrane would have an infinite number of “corresponding points”, which would require an infinitely large basilar membrane. I’ve certainly met “big headed” audiophiles but I think I’d remember if I’d met one with a head infinitely bigger than the entire universe! Human beings have approximately 3,500 cilia in the basilar membrane (arranged in bundles) which certainly is not an infinite number and is obviously also significantly fewer “corresponding points” than the roughly 20,000 sine waves/frequencies which encompass human hearing.
Both the mojo and E30 were also fed by their optical input so I am certain there is no jitter or noise from the PC getting injected either.
Great, so you have a system that breaks the laws of physics. Thanks for letting us know, it must be very enjoyable (when listening in a different universe)!
You speak of other blind testing being done but I doubt anyone else have done blind test with as much rigour and electrically clean conditions as I have.
That’s just funny, as I don’t know anyone else who has done a blind test with as LIITLE rigour as you have. Certainly there are no scientific blind tests with as little rigour for many decades because science has mandated level matching to within at least 0.1dB since the 1950’s. Are you really claiming science has not done any blind tests in the last 70 odd years or just that you have no idea what ”science” or “rigour” mean?
music is far far more complex than what a crappy REW can ever hope to capture
Err, REW doesn’t capture music, it analyses frequency content. Don’t you even know the difference between a frequency analyser and a digital audio recorder?
we currently dont have the technology to record and analyze music waves with sufficient temporal resolution.
BS! First of all, there’s no such thing as “music waves”, there are analogue waveforms, digital representations of them and acoustic sound waves (that may or may not be interpreted by the human brain as music). Don’t you even know the fundamental basics of psychoacoustics? Secondly, what is a “
sufficient temporal resolution” of sound/music for human hearing and what is the temporal resolution of recording technology? If you cannot correctly answer BOTH of these questions then your assertion is just BS you’ve made-up! Is BS you’ve just made-up “YOUR scientific depth”?
maybe you can read up some more actual books and find out.
Ah, perfect hypocrisy, why don’t you read some actual book and find out? You can start with the previous questions and find out the temporal resolution of human hearing and of digital audio. Although maybe try introductory beginner books on ear anatomy, physics, psychoacoustics and basic science/scientific rigour as well!
I could do with a good laugh though, so please recommend a book where I can find out about audiophiles with infinitely big heads, sound waves comprised of an infinite number of sine waves and how rigorous science can only be performed by you and your girlfriend! lol
I won’t bother with the rest of your post, it’s just more of the same BS, which is contradicted by the facts/science (and even basic common sense) and then you claim scientific rigour/depth/validity?! That level of ridiculousness is not uncommon with many ill informed/ignorant audiophiles but why on earth would you try that in a science discussion forum, are you really that deluded?
G
Edit: Removed specific references to “countable infinity” in light of
@sander99 post #165.
