MrHaelscheir
Hello. In response to WaveTheory's recent "Cables Matter" videos, claiming such things as cables being able to "smooth out peaky treble" or some cables having innate "peaky treble", and their original four similarly named videos covering the possible science behind the audibility of cable differences, I have gone ahead and taken a few measurements with my in-ear microphones obtained from Earfish (I will be reporting on my findings with binaural headtracking soon), whether or not one sees benefits to the using of real human ears. At best, these measurement conditions should reveal practical frequency response variations caused by the mere act of slightly moving your head or jaw.
In short, the "cable science" videos explain fundamentals reasonably, making very clear to all of us what sound is (unfortunately never mentioning magnitude or phase versus frequency response; take some time to convince yourself that "sound" is a collection of longitudinal air vibrations that can be divided into individual superimposed sine waves arriving with varying phases, and that audio systems alter this in various ways, whereby true transparency aims to leave this frequency content untouched and not introduce any new sine waves that don't belong (nonlinear distortion)), then in the third and fourth parts mainly point out miniscule phase distortions caused by cable velocity factors (without ever mentioning the word "phase") as potentially causing time domain waveform changes detectable by human pattern recognition facilities (I have many issues with this).
This report will proceed to demonstrate the lack of frequency response differences between the measured cables mind between balanced and unbalanced that cannot be attributed to minor movements of the headphones or skin, and that phase variations due to head movements disturbing the headphones are most likely to create significant phase distortions past 1 kHz far surpassing any that could be introduced by cables, such not considering literature on the inaudibility of phase distortions in most audio.
Disclaimer: Note that I am not discounting the reality of these subjective cable experiences for users, but rather the cause or the belief that these subjective effects are physically innate to the cables rather than consistent perceptual distortions molded by knowledge of what cable one is listening to. As I had discussed at length in https://audiosciencereview.com/foru...rent-are-that-many-confused.9245/post-1522578 (post #5,428), if those subjective effects are consistent to you within your practical, sighted listening conditions, then all power to you to enjoy your gear, but just know that there is currently no science that should suggest that these effects are remotely guaranteed to be perceived by others and that such investments are more effective than properly done EQ and other digital processing.
2023-11-12 update: Please disregard all theorizing below regarding the phase response being extremely sensitive to the slightest perturbations to the headphones' or in-ear microphones' positioning. After acquiring a proper audio interface to ensure proper sample synchronization, as can be seen in https://www.head-fi.org/threads/con...bles-mattering-for-audio.970430/post-17816683 (post #8), the phase response consistency has been drastically improved, whereby the phase responses between these cables though these respective headphones are effectively identical.
Methodology:
In https://www.head-fi.org/threads/mez...eadphone-official-thread.959445/post-17743502 (post #5,152 and the following), you will see my acquisition of a pair of in-ear microphones from Earfish and EQed frequency response, phase, and distortion measurements taken for the Meze Elite and Arya Stealth. Below is the full measurement methodology for this report using that equipment:
Observations:
The full REW .mdat files containing the measurements can be found at https://drive.google.com/file/d/1XG3cA9byn0p8BHBqYiOx4wF8s5DS8-KV/view?usp=share_link (the file size is too large to attach here) with comments explaining each measurement.
Only left channel measurement images are shared in this post since the right in-ear microphone was found to have bass and top octave roll-off compared to the left in-ear microphone which was found to be more accurate, roughly confirmed against outdoor on-axis measurements of a Genelec 8341A calibrated with GLM.
This report assumes an understanding of how to read magnitude and phase versus frequency response graphs as well as REW distortion graphs, all of which can be learned online. Consider frequency response graphs as summarizing the "wave superposition" described by WaveTheory in their "cable science" videos.
The below graphs show the magnitude versus frequency response on the top and the unwrapped phase versus frequency response on the bottom.
Meze Elite:
Here, we see a comparison between two balanced cables of different tiers within the same brand. The below measurements targeted 105 dB SPL uncalibrated on the "Measure" window's "Check levels" output, corresponding with around 96.5 dBA when placing an A-weighted SPL meter with wind shield lightly against the inner driver grill of the right driver unsealed and facing outward.
Magnitude and phase versus frequency responses:
At this point, you will have to just trust that I definitely did swap the cables and correctly kept track of the measurements, since the frequency responses are nigh identical (within the 20 Hz to 20 kHz audio band; I would highly doubt that ultrasonic performance matters, especially when your DAC already filters the ultrasonic components out per the Nyquist-Shannon sampling theorem). When switching between the premium and stock measurements for the same channel when viewing with REW, you will see minor variations of the sort you would see with the same cable when slightly disturbing the headphone's or in-ear microphones' positioning. So how are you to know if the differences that you hear are due to the cable or due to the headphones being positioned differently, especially in the case that you remove the headphones first to change the cable? Regardless, what is clear is that the 99.95% copper cable certainly does not (measurably) smooth out treble peaks mind the 6 kHz peak, and neither does the act of plating the copper with silver increase the brightness, both effects being achievable for free with EQ. The only reason I own this premium upgrade cable is that my preferred 4.4 mm termination was not available for the stock cable, and that it feels nice and is a joy to look at every day as is the Tungsten version of the headphone itself.
The stock cable's measured magnitude versus frequency response was maybe a fraction of a dB lower than its premium cable counterpart's, though whatever factors in the cable or DAC/amp may have contributed to this, I doubt that this would be enough to cause perception of massive increases in "soundstage" or "resolution" among other claimed phenomena.
You may notice that the phase responses past 1 kHz show quite noticeable differences (not considering the literature regarding the inaudibility of phase distortions for certain audio; in short, the cochlea performs the equivalent of a Fourier transform such that neurons are only excited by individual narrow frequency bands, your brain this primarily hearing the magnitude response sans phase information; see https://www.phon.ucl.ac.uk/courses/spsci/AUDL4007/12.pdf which explains the entire auditory path), which surprised me at first, though again, I thought it common knowledge that these are largely inaudible in these conditions (except maybe for the quality and decay of sharp transients). After conducting more measurements as included and annotated in the full REW measurements, I found that even for the same cable while sitting as still as possible, small perturbations from my unavoidable slight head movements or ear twitches between measurements were likely the cause of these significant changes in phase response past 1 kHz, unless it is rather an error of my measurement system. Otherwise, when looking through the various measurements, it could be figured that any differences in phase response between the two cables were comparable to the differences that could be measured from the same cable due to head perturbations, there also being some measurements where the phase response for both cables are quite similar. Thus, there is likely no significant difference in phase response between these cables.
Distortion comparison:
As can be seen, the distortion profiles and levels between the two cables when volume-matched are largely the same. I am unable to compare measurements for electrical noise rejection.
In subjective sighted comparisons, I personally have never noticed any tonal differences or any sounding "wider" or "more detailed" than the other.
HiFiMan Arya Stealth:
Here, we see a comparison of a stock unbalanced cable with a balanced cable from a different brand.
Figure 3: Distortion measurement for HiFiMan Arya Stealth with fabric sleeve stock (crystalline silver and/or copper) cable, unbalanced and volume-matched
Figure 4: Distortion measurement for HiFiMan Arya Stealth with Meze Mono 3.5 mm to 4.4 mm Balanced Silver-Plated Copper Upgrade Cable
Again, the distortion profiles between the unbalanced and balanced cables when volume-matched are largely the same.
Regarding cable phase distortion:
WaveTheory's videos did well to explain the fundamentals of sound, and made a reasonable argument on the invalidity of the term "bias" or "placebo" when the signals are in fact measurably different, though I would vie that "confounding variable" is perhaps the term that should be used. The problem is that they predicated this and the entire "human pattern recognition" or "auditory camouflage" argument on velocity factor measurements which they failed to identify [[rather did not describe as for pedagogical reasons]] as causing phase distortions which should not be audible--actually, looking at https://www.audiosciencereview.com/...se-distortion-shift-matter-in-audio-no.24026/, the research referenced was specifically for the audibility within reverberant rooms through speakers, whereby I am not sure of similar research for headphones (Amir does mention headphones), but again, I have shown that merely moving your head or jaw would surely cause phase differences greater than what most cables could induce; then we would need to discuss the science for determining how these could possibly cause large perceptual distortions of magnitude response mind imaging and soundstage if at all. The assumption was that the time domain differences in waveforms from these phase distortions would be processed by the brains as changes in patterns that could be detected through extended listening, but again per https://www.phon.ucl.ac.uk/courses/spsci/AUDL4007/12.pdf, the "pattern" the brain is processing through the nerves of the cochlea is rather more like a spectrogram containing magnitude information excluding phase information. Now, perhaps there are mechanisms through which phase distortions do cause the cochlea to report alterations to this "spectrogram" (e.g. supposed hair cell sensitivity to phase inversion), but again, as shown, head movements or ear twitches on their own may induce these phase differences.
Phase response of some other systems:
One interesting thing. Behold the Sennheiser HE-1's ultra-smooth frequency response (measured during a Bay Bloor Radio listening event), but substantially decreasing phase response (wrapped) which IIRC implies that it isn't minimum-phase:
Perhaps this monotonically downward slope may be related to the HE-1 as an electrostatic headphone being a capacitive load, or phase distortions inherent to electrostatic headphone amplifiers. Subjectively, I would argue that I only "heard" the tonality and that I preferred the sound and presentation of my EQing results from https://www.head-fi.org/threads/mez...eadphone-official-thread.959445/post-17743502 (post #5,152).
Finally, here is my left in-ear measurement while 1.5 m in front of a GLM-calibrated Genelec 8341A (very neutral and excellent directivity active studio monitor) in my backyard with my head directed 30 degrees to the left (left ear thus facing away from the speaker):
This by chance shows a phase profile much more similar to my headphone measurements while the others show more phase "extension" and peaks past 7 kHz, some measurements from the other channel or configurations showing more greatly decreasing phase profiles.
Conclusion:
It has been shown that at least these cables for these mostly flat-impedance headphones have effectively identical magnitude frequency responses, minor differences being attributable to minor movements of the headphones when one moves one's head or switches the cables, the treble phase response appearing to be the most greatly affected by these slight perturbations. Furthermore, these motional perturbations cause greater changes for the same cable than the cables themselves possibly could within the audio band. Likewise, when volume-matched, no appreciable differences were measured between a stock unbalanced cable and a slightly more premium balanced cable from a different brand.
Regardless, the point is that though individuals who report differences do perceive them, assessment of causation must not forget that the system includes both the knowledge of the cable and the actual signals reaching one's ears, whereby in the equation of ab + c = d, when b (knowledge of the cable) and d (subjective sound) change, and coefficient a ("susceptibility") for the individual happens to be large enough, so long as those changes for them are consistent in their listening environment, the individual need not be offended by the notion that c (the audio signal) is in fact demonstrably unchanging or that in the grand scheme of the '+' operator of human hearing, such tiny changes in c are inaudible. Otherwise, perhaps indeed, companies had ought to be held accountable when they claim changes in c that demonstrably do not exist in the audio band.
Given this, I will continue to advocate that if you want to achieve both clearly measurable and reliably audible changes and improvements, this can be best achieved with EQ for which the only cost is the time spent on learning how to use it effectively. But this requires lifting any bias that EQ degrades audio, whereby as I have shown in https://www.head-fi.org/threads/mez...eadphone-official-thread.959445/post-17743502 (post #5,152) and my other EQ posts, EQ can measurably eliminate peaks, cleaning up the sound, correct tonal balance for excellent and transparent richness, clarity, and naturalness, and in the case of minimum-phase EQ even flatten the phase response.
Methodology:
- I am seated on my computer chair before my computer desk and measurement equipment. The ambient noise level was between 35 to 40 dBA.
- The in-ear microphones are inserted as deeply as possible with the capsules facing the ear canal entrance such that the ear canal resonance is excluded from the frequency response measurement; the memory foam mounts also protect the eardrums from the loud volumes needed for high-SNR measurements.
- The included Axagon USB HQ Audio Mini Adapter is mounted to the back of a headband (meant for HRTF measurements), the in-ear microphones wires being held taut between the headband and the head to prevent the seating of the in-ear microphones from being disturbed during and between measurements. The wires held or pulled up so that they are pressed only by the upper part of the headphone earpads.
- Room EQ Wizard (REW) is used to facilitate the frequency response and distortion measurements, the Axagon adapter and FiiO K9 Pro ESS DAC/amp being selected as the input and output devices in non-exclusive mode, all EQ applications being disabled. The Windows Mixer volume settings for both devices are set to 100%.
- The DAC/amp is set to low gain.
- The cables are connected directly to the DAC/amp's respective outputs with all other ports unoccupied.
- The "Measure" button on the upper left of REW is clicked, the measurement length (in samples) set to 4M to maximum single-repetition noise reduction, and the sample rate set to 192 kHz purely to reduce the time duration of the measurement.
- "Check levels" in the "Measure" window is clicked and played for each channel to facilitate volume matching such that switching between measurements in REW best shows the identicality.
- "Start" in the "Measure" window is clicked and my right hand placed on top of the DAC/amp as I have found that this somehow reduces the noise floor by around 10 dBFS in the "Check levels" sound level log on the lower left such that vibrations from my heartbeat are visible. I keep my head and body still for the duration of the measurement with light, regular breathing, avoiding twitching my ears.
- The "Controls" button on the upper right of the measurement viewing window is clicked and "Unwrap Phase" clicked, the phase graph then positioned with the +-360 buttons for convenient viewing (these settings may or not be carried over to your own instance of REW, and you might also have to click "Limits" on the upper right and "Apply Settings" for the default to obtain the intended viewing scale).
- Cables are switched with the headphones still on the head, trying to disturb their position as minimally as possible.
Observations:
Meze Elite:
Figure 1: Frequency response for Meze Elite hybrid pads with Meze OFC 99.95% Copper Standard Cable Balanced 4 pin XLR Cable
Figure 2: Frequency response for Meze Elite hybrid pads with Meze Mini XLR to 4.4 mm Balanced Silver Plated PCUHD Copper Premium Cable
Figure 3: Distortion measurement for Meze Elite hybrid pads with Meze OFC 99.95% Copper Standard Cable Balanced 4 pin XLR Cable
Figure 3: Distortion measurement for Meze Elite hybrid pads with Meze Mini XLR to 4.4 mm Balanced Silver Plated PCUHD Copper Premium Cable
Figure 1: Frequency response for HiFiMan Arya Stealth with fabric sleeve stock (crystalline silver and/or copper) cable, unbalanced and volume-matched
Figure 2: Frequency response for HiFiMan Arya Stealth with Meze Mono 3.5 mm to 4.4 mm Balanced Silver-Plated Copper Upgrade Cable
Again, the frequency responses are virtually identical (within the audio band). Likewise, the phase responses are similar, and as you would see in the full REW measurements, can vary noticeably for the same cable. Likewise, in practical listening, mere head movements will likely induce high-frequency magnitude and phase response differences greater than what a properly designed cable would induce. At least when directly A/Bing an unbalanced cable with a balanced cable without volume-matching (or worst case "volume-matching" until the preferred cable sounds "better"), there should be a clear difference in volume which would obviously have major subjective effects. Otherwise, the only reason I have this cable was because it was what the shop offered when I asked for a balanced cable purely for the purpose of taking advantage of the DAC/amp's power and noise capabilities through its balanced topology.Figure 2: Frequency response for HiFiMan Arya Stealth with Meze Mono 3.5 mm to 4.4 mm Balanced Silver-Plated Copper Upgrade Cable
Figure 9: Sennheiser HE-1 magnitude and phase with respect to frequency
Figure 10: Left ear HRTF when facing 30 degrees left
Conclusion:
