https://www.head-fi.org/threads/testing-audiophile-claims-and-myths.486598/post-15509411
This is a good one on the whole cable subject I think.
This is true as well.In the laws of physics, different metals have different conductivities which add to the output impedance of the source. Which is why I believe different cables have different effects on drivers
An IEM with more ohms require more power. Since I am not knowledgeable in this topic, can you explain why a 32ohm IEM would not be affected by output impedance?This is true as well.
Changes in output impedance will alter the sound of a few IEM that has low impedance (Andromeda being an example). Changing from one DAP to another can alter the sound due to differences in output impedance. But a cable shouldn't change it that much unless it's a really long cable.
The IMR OM is not one of those IEMs that is affected by output impedance though since it's rated at 32ohms.
IEMs that use all BA drivers can have its frequency response changed (as noted by @NellieG above) when the output of the DAP to IEM is less than 1:8 ratio (example DAP outputs 3ohms while IEM is 10ohms). The andromeda is a good example where some users report having a lot of bass while others say it doesn't have any bass due to the DAPs they're using. Most andromeda owners will recommend a DAP that has less than 1ohm output.An IEM with more ohms require more power. Since I am not knowledgeable in this topic, can you explain why a 32ohm IEM would not be affected by output impedance?
There’s two threads for cables: Link to cheap & Link to not cheap cablesI'm actually curious what other users in this thread think about cables. I hope this discussion does not end and more people chime in
I would actually want to try and test this.With dynamic driver IEMs, the output doesn't affect the frequency response, as far as I know. And so with using different cables it shouldn't alter the sound
I second this. There is separate section on this forum for that sort of discussion and it should be kept there.How about this, if someone feels that she/he would like to share impressions when using a new cable, that they do this in the respective cable thread, as this has not so much to do with the IEM itself. People interested in cables can look there to get informations about relevant cables for their IEM. In this case we would not drift here (and in lots of other threads) into these general discussions about cables (which I find quite strenuous, because it is all said about this topic).
