Can anyone who has or has heard the Red comment on how big an upgrade the Elan would be? I'm thinking of picking up one of the B stocks. Or should I just save my pennies for Dark Matter?
IMR Audio : Sonic Adventures & Impressions
- Thread starter NellieG
Rafinnnnnn15
I would go better for the dark matter friend instead of the ELANCan anyone who has or has heard the Red comment on how big an upgrade the Elan would be? I'm thinking of picking up one of the B stocks. Or should I just save my pennies for Dark Matter?
AlexCBSN
Amt drivers announced... damn, I've been lurking russian forums for those
monsieurfromag3
I’ve forgotten what those were, are they the ones Bob said couldn’t be engineered yet?Amt drivers announced... damn, I've been lurking russian forums for those
+1 for sleuthing through obscure Russian forums
justsomesonyfan
- Sep 24, 2013
i guess the wait isn't long, amt/dd/BC custom iem when?
AlexCBSN
The problem with amt drivers is that they are normally massive, I doubt he’ll put em on a combo nor custom, though who knows what’ll happeni guess the wait isn't long, amt/dd/BC custom iem when?
justsomesonyfan
- Sep 24, 2013
fair, i have an amt/dd iem and it's pretty much solaris sizedThe problem with amt drivers is that they are normally massive, I doubt he’ll put em on a combo nor custom, though who knows what’ll happen
cleg
- Oct 14, 2011
And of course, I couldn't skip Elan with review
I bought the Azlasedna crystal tips the other day and they are now my favourite tips for Semper. They bring forward the upper mids a bit and are a good fit, they seem very durable too. Highly recommended.
I've gone through many different tips with the Semper, but I finally settled on SpiralDot++. ePro horn-shaped tips were brilliant, too, but they caused the shells to protrude from the ears too much.I bought the Azlasedna crystal tips the other day and they are now my favourite tips for Semper. They bring forward the upper mids a bit and are a good fit, they seem very durable too. Highly recommended.
But I will keep the crystals in mind, expensive though they are.
I was using the Spiral dots before myself. They are good too. But I feel these are better, at least they work better for me with Semper , and in general I love the material and how they look too.I've gone through many different tips with the Semper, but I finally settled on SpiralDot++. ePro horn-shaped tips were brilliant, too, but they caused the shells to protrude from the ears too much.
I should add that there are 2 versions of the Crystals , the regular one and TWS version. To clarify I'm talking about the regular version.I've gone through many different tips with the Semper, but I finally settled on SpiralDot++. ePro horn-shaped tips were brilliant, too, but they caused the shells to protrude from the ears too much.
- Sep 20, 2009
Did you buy a different size than silicones? I've heard Xelastecs require one size down to fit.I should add that there are 2 versions of the Crystals , the regular one and TWS version. To clarify I'm talking about the regular version.
Yes they are on the larger side , I went with the ML instead of my usual L. Depends on the IEM nozzle size and also insertion depth that you want to achieve too. The M would have worked too I guess.Did you buy a different size than silicones? I've heard Xelastecs require one size down to fit.
Thinking about picking up a used Elysium to check out the bone conduction tech. but there doesn't seem to be too many proper reviews of this model. Those who have it, how do you find that it fares for primarily indie rock music? I am a big fan of vocals and want an engaging midrange that is not v-shaped. Would Elysium and its planar driver give me the full lower mids I am looking for?
Or perhaps the Avalon would be a better fit? I already had a few hybrids with EST's so was leaning towards the Elysium for the planar driver. Thoughts?
