malfario
Silver or grey?
Sorry for the late reply, I’m using silver filter. I’m pretty happy with this combination, though I am willing to give pink nozzle a shot with the Tennmaks to see how it goes.
Silver or grey?
Do the other filters not do their job well enough for you that you look for external ways to tame the treble?
What cable is this? I am looking for 90 degree one for myself. What material is it?
This is a Linsoul DUNU DUW02 High-Purity Silver-Plated OCC Copper Litz Wire (0.78mm 2pin) cable.What cable is this? I am looking for 90 degree one for myself. What material is it?
I'm not concerned to be honest, noticed its mainly some female vocals, fully expect it to settle after a few hoursI wonder if it's possible to eliminate the harshness for all? There are so many different files produced. I don't know.
I am not concerned too. I can support harshness.I'm not concerned to be honest, noticed its mainly some female vocals, fully expect it to settle after a few hours
Enjoy your ride with them over the next several hours. This is not your first IMR rodeo, so even though you don't know what to expect, you know what to expect . I know that with the OG EDP the bass developed and the treble extended past 150 hours and I'm convinced they were still getting better into 300 territory.Finally received the EDP+ a few hours ago. Like it was said before these are very bass lite compared to OM and Semper. But no issue for me as I like a well balanced sound. A bit dark and can do with some more air and extension in the treble. Other than that they are a more intimate and smoother version of Semper at this point. No sibilance at all which is a big plus. They fit me great And sit flush in my ears.
I've settled on Spiral Dots++ and grey/blue combination for now. Excited to see how they change with burn in.
Thanks I will . Hope you enjoy the Elysium as well. I look forward to the impressions.Enjoy your ride with them over the next several hours. This is not your first IMR rodeo, so even though you don't know what to expect, you know what to expect . I know that with the OG EDP the bass developed and the treble extended past 150 hours and I'm convinced they were still getting better into 300 territory.
Screwing the nozzles on the IEMs so hard that I feel like my fingers are going to break when I try to remove them.
I ended up getting it loose when wrapping my cotton shirt around it. Using the leather cable tidy is a really good idea though. Thank you for the suggestion!I found removing the rubber/silicone rings from them helps a lot. If one is then still a little hard to remove I use the leather cable tidy to grip the filters and nozzles. Generally much less finger pain.
BC is what i was expecting though the first days i wasn’t impress either, i thought it was a bit bland, I’m on blue on blue, thinking going red bottom / blue for the sake of clarity, I’m loving em too now, the aten driver has started to rise, and the ADLC CNT driver is adding some serious mids and highs. Impact is great. They do carry some impressive bass weight, must admit that i was biased cause i was using FOCUS EDM iem, which is one bass head huge headphone, it complements the BC thus far.I got the BC in about a week ago. I used them for a few hours on stock black nozzle/black filter setup and honestly wasn't very impressed. Bass was plentiful but didn't sound right to me. I had some time to go through a few filter setups today and find that grey nozzle/blue filter with spiral dot ++ tips is working great for me. I got the full body goose bumps and my jaw dropped to the floor. These are definitely keepers.
A few things that rub me the wrong way about how the company does things are:
-Providing tracking that says the product is on its way but doesn't update saying that it's actually shipped until days after.
-Not providing a tool to remove the back plate to switch plates.
-Screwing the nozzles on the IEMs so hard that I feel like my fingers are going to break when I try to remove them.
All are relatively minor issues for me that have nothing to do with the actual product quality.
These are definitely the real deal sound wise!
