davescleveland
- Jun 1, 2015
Call me crazy but I put a little bit of superglue on the 2 pins of any cable and now they don't fall out
I put a double sided band tape.Call me crazy but I put a little bit of superglue on the 2 pins of any cable and now they don't fall out
Everything I tried from Nice HCK, Xin HS, CEMA has fit like a glove with IMRs. In fact all of those cable have fit with my fusions perfectly and with the IMRs (EDP & RAH) I had to use a nail file to trim the plastic part around the pins a little. Using the nail file on a pair clippers I give the plastic extension 10 strokes on the top, 10 bottom, 10 on either side until it fits. Doing like this gives a really tight fit in the IMR but leaves it working in the others. Which tells me the IMR fitment is a little off from other brands.Did you had to repair the EDP?
I'm looking for the Dunu cable because of the modular system but now I'm seeing it doesn't have recessed slots. What cables could you recommend?
I use epoxy!I put a double sided band tape.
Maybe you can put your new cable in your new case and they can de-stink together lolMy IMR Aten with its new XINHS cable. I had to do some filing on the connectors, but now they sit securely in the socket.
I am quite surprised with how soft this cable is. It also has a pretty strong smell, unfortunately, but I expect that to go away with time.
I am extremely pleased with this seller's service.
Haha, what an excellent idea!Maybe you can put your new cable in your new case and they can de-stink together lol
I think there has been a less that perfect batch of cables - Im sending back an IEM to Bob to check something -
I'll include one of these loose fitting cables with it and mention how a few of us have experienced the same thing
(I slightly bent one of the pins to get a tight fit!)
We are a creative lot
EDIT: Ive a lot of IMR iem's and the only problem cables I had was some of the new 4.4mm ones. Can't be easy manufacturing to such precise fits with this kinda stuff though!
How did the cable make the 'earpiece get loose' - with mine it was not quite tight enough so occasionally the shell would fall off!The new 4.4mm cable made my EDP and R3 right earpice to get loose. He's sending me new cables but probably I'll need to sent the units for repair. Strangely I have an old balanced NiceHCK cable that has a better fit.
Was your cable the wrong shape or too big . . .?
Lets keep this all positive and get these reports to Bob
Of course I appreciate how these things are frustrating but Bob is great for support & i im sure if we can communicate our shared experiences it helps improve and stop such issues happening in the future
Do you mean that the inner female connection part inside the shells of your IEMs became loose ?I have no idea because I had no problems with the 2.5mm or 3.5mm cables.
