You can probably get XINHS to make you an 8-core graphene cable for less. Or else wait until the NiceHCK cable is half that on some sale.I will first try a 4 core that costs 39 usd with the semper. If I am happy, maybe I will buy the 8 core, but it costs 143 usd from nicehck.
IMR Audio : Sonic Adventures & Impressions
- Thread starter NellieG
Xinlisupreme
Do you think are same cable and differ only for price?
jon parker
Quick video explaining 'Bone Conduction'
vis a vis - Bobs new IEMs coming later
weexisttocease
Does anyone have the Dunu Duw02 cable with the IMRs? I have the EDP and Halcyon and both have a loose right earpiece. I believe it's because of the 4.4 cable. Bob is sending me a new cable, otherwise I'll have to send the earpieces for repair. It's strange since I don't have the same problem with the RAH.
holsen
I think you'll like the 4 core; it is the 4 core version of the 8 Core DarkJade from Nice HCK. XIN HS is the OEM that makes the Dark Jade with Nice HCK branding.I will first try a 4 core that costs 39 usd with the semper. If I am happy, maybe I will buy the 8 core, but it costs 143 usd from nicehck.
ChrisOc
I had the same issue with the EDP. I have Dunu DUW02 cables. The DUW02 is a good looking cable with very practical features but NiceHCK cables give a more secure fit with IMR earphones because of the recessed slots.
Tiaa
That's what they say.Do you think are same cable and differ only for price?
Tiaa
Has anybody try a curved 2 pin connector with the semper shell? Is it comfortable?
holsen
I have it directly from XIN HS - they make the Dark Jade, the pure silver and several other cables for Nice HCK and others.That's what they say.
ChrisOc
Good to know!
Tiaa
Cool, thanks for the info. I will try to speak with them. But I have to wait till China holiday. I will also try a pure copper silver plated cable.I have it directly from XIN HS - they make the Dark Jade, the pure silver and several other cables for Nice HCK and others.
Honestly, that guy is so helpful and accommodating that he deserves our custom. And their cables are priced quite reasonably, I think.Cool, thanks for the info. I will try to speak with them. But I have to wait till China holiday. I will also try a pure copper silver plated cable.
Kundi
XINHS has a 8 core for $65 USDI will first try a 4 core that costs 39 usd with the semper. If I am happy, maybe I will buy the 8 core, but it costs 143 usd from nicehck.
https://www.aliexpress.com/item/100...68#1000022185#1000066059#0_668#3468#15612#327
weexisttocease
Did you had to repair the EDP?
I'm looking for the Dunu cable because of the modular system but now I'm seeing it doesn't have recessed slots. What cables could you recommend?
Total: 30 (members: 0, guests: 30)
