Dalamar
- Jul 4, 2009
Christ, that thread is hopeless/. Only way to stop the disease in there from spreading is to nuke it.
hah, you're even more hardcore than me...I've met my master
there's a lot of starving trolls to feed if you feel up to the task: http://www.head-fi.org/forum/thread/493678/a-better-sounding-alternative-to-foobar2000-or-a-musing-in-the-realm-of-bit-perfect-streaming/240
BTW, if I may respond to your post:
~Solid State drives sound better than spinning ..I don't believe it, it's prolly EMI/RFI related...and also having the HDD feeding groundloops but I use a USB Isolator to my S/PDIF transport.
~WASAPI and ASIO sound different, WASAPI sounds smoother fully dependent on your audio drivers.
~ASIO and Kernel streaming sounds different, ASIO sounds more harsh KS sounds more clean
what about ASIO4ALL(being a KS>ASIO wrapper)? I know either cMP or XXHighEnd coder(can't recall which one) said that he couldn't stand the ASIO color?!
~Every music software player sounds different for every operating system fully agreed
~Mac sounds different than PC or Linux never tried
~Most DAC's sound different of course they do
~Different IC's sound different ditto
~Power cords sound different never tried, I like to install ferrites on them, though.
~Linear regulated powersupplies sound better than switching X2, even a blind man can see it
~Mac's sound better with more RAM I'm dubious
~upsampling sounds different yep, it sounds brighter due to the increased THD(you can easily measure it in WaveSpectra)
~headless computers sound better than computers with attached monitors again a story of EMI/RFI, I'd have to hear it to believe it
I guess this PDF is your bible? http://photos.imageevent.com/cics/v03theartofbuildingcomputertrnsp/The%20art%20of%20building%20Computer%20Transports%20v0.3.pdf
I've applied most of his non-tinfoil tweaks...all my system processes run in low priority on single cores and my media players run in high priority on the 4 cores w/ their audio thread in realtime priority.
So whaddayasay about ASIO4ALL? a bastardized mix surely, but does it sound like KS or ASIO to you?
yeah, the GUI in XXHighEnd is horrid...and I'm not paying $100 for a half-working player when there's Reclock and uLilith.
indeed, JRiver's software should be able to provide gapless audio through Reclock....but their bloated GUI really puts me off.
Re: Media Center 13 Feature Requests « Reply #298 on: December 10, 2008, 07:36:17 am » | [size=smaller] [/size] |
A4A is KS wrapped in a ASIO cloak. I don't like it.
Well, there's a forum where audio drivers engineers chitchat, and they're always blown away by how well A4A works.
Did you try uLilith? I love this player so much, it sounds more analog that Reclock, which is really "in your face"...great for music, unforgiving for poorly recorded music. uLilith SQ superiority is no black magic...everything works in 64fp(from the lossy audio decoders to the native VST plugins support/volume attenuation). Reclock runs a small WASAPI buffer in realtime priority, and you can set uLilith to do the same.
Yes I have tried uLilith is does sound great. Before that I was using KMPlayer with ReClock. But since then I have moved to 100% Linux with Music Player Daemon. This allows me a very small operating system with no bloat [the distro I use has only the basics], and a very small program that runs in the background to serve up the tunes MPD. There are numerous VST plugings for Linux which can be used but I don't use them.
How do you find Linux in comparison to Windows for audio tasks?
P.S. I know this is more than what you asked for but I just wanted to give you some background.
Can I have a link you your website. Most interesting some of the stuff you have just posted. Thanks a bunch for posting all that, I think it's very useful information. All of it.
something tells me that you're coconut from the Reclock forum
the day linux will have Reclock/ffdshow and madVR, I'll think about it.
