- Oct 6, 2013
As far as I know, the UE adapter is indeed just a 100ohm adapter and nothing more (*not a voltage divider). So basically you just added 100ohm more to the AP100's output impedance.
Thank you ClieOS!!!
I wonder if they would have something similar to this: http://www.ebay.com/itm/Impedance-Adapter-Plug-75-ohms-3-5mm-to-1-4-inch-plug-/251464612918?pt=US_Cables_Snakes_Interconnects&hash=item3a8c757c36 but with 3.5mm connector. I think 75ohm might work as good as 100ohm, just need 3.5mm plug...
... nevermind, found Ety's adapter where you can select different impedance option: http://www.ebay.com/itm/Etymotic-ER4P-to-ER4S-3-5MM-plug-resistor-adaptor-/281276949691?pt=US_MP3_Player_Cables_Adapters&hash=item417d69a4bb
