Magicman74
- Jan 16, 2012
Yeah, I use med-tips with a wide opening. It's gives the bass a little bit more. If you've heard the Gr06?, It's the same Bass but a tad bit more then the 06. The GR02 being called the Bass Edition is a reach IMO but it works quite well. The GR99 on the other hand has much more Bass power but not as crisp as the 02s' I'd say for Rock, Pop, ect..The GR02, For Dub, Rap ect..The Gr99....But either works quite well.. It's really Hard to tell much of a difference between the 99 & 02, The Bass is about it, You really have to give it a hard listen to tell the rest of the spectrum apart, I'd rather enjoy the music instead
Got mine today. It's hard to find any fault with them. A bit more bass, perhaps?
A great bargain at the price, surely. Magician, I thank thee!
Update:
I just switched to medium single-flanges, and the boost got a very pleasant boost. Perfect.
