luiswu
I put this between the Ifi Zen Streamer and the amp, it is a tube preamp with volume control. It is placed between the IFi and the line input, not the preamp input. NOTE!! It is the Japanese version, it is the one that sounds good.I am having a problem.
I have a Zen Stream connected to Topping DX9 (DAC / headphone amplifier / pre-amp). Works great.
I realized the Topping is overkill so moved it out of this chain. I changed nothing. Unplugged the power chord from Topping and the USB connection.
I ordered a HiFiMan EF400, it arrived and I plugged it into the chain. Connected power and USB. Turned on the EF400 and beautiful sound but doesn't get loud, at all. Not even with the easiest to drive headphones. Tried different USB cord, restarted the Zen Stream. Same.
I am returning the EF400 and they are swapping it out. I'm just wondering - is there anything in a Zen Stream that could make the output low, low low in volume that the new DAC / amp amplifying the sound isn't enough to 'drive' headphones properly, or is it most likely a bad EF400 (which we all think it is)? The volume is 'fixed' in Zen Stream configuration, btw. Streamed via ethernet from Roon.
The improvement is very substantial with the magic of the tube making the music sweeter and more pleasant, softening the amplifier's transistor.
