pekingduck
- May 16, 2009
How does the amp section fare against TOTL portable amps such as the Vorzuge Pure II, Portaphile 627 etc (in terms of SQ not power) ?
Does anyone uses the ifi with an iPhone? I listened to spotify for like an hour. Suddenly my iPhone is down to 50% battery
What?!?!
Does the iPhone charge the ifi? Maybe it drains all the power and transfers it to the ifi....
Any advice?
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Basically, if you want the device to use its own built in battery instead of your smartphone's battery, switch on the micro iDSD before connecting it
Yea will do it from now on. But disconnecting it every time I'm not listening to it anymore is kinda well. Not. User friendly.
Don't you think?
But other than that the idsd is amazeballs
You only need to disconnect it when you want to charge it. Otherwise just leave it connected and leave it turned on. It goes to sleep when no music has played for a few minutes so the battery is conserved. There is no need to keep switching off or disconnecting.
Registration of the Octa-unit is through the normal product registration page right?
After that then just wait for invitation right?
Is there any indication of the unit number from the serial number?
My Micro iDSD serial number is microD20711
Tx!
I've been listening to the micro iDSD feeding a micro iCAN lately and that has been really good. I then switched over to using the micro iDSD to feed a tube amp with NOS Mullards tubes.
Wow!
If you have the micro IDSD, you owe it to yourself to try it connected to a really good headamp. The versatility of this thing continues to impress, so the buzz definitely hasn't worm off after 1 month+ of ownership.
Wow!
The find the iDSD micro to be better than the other two combos in technicalities but I'm unsure of synergy with the HD650. In terms of power, Micro iDSD > Duet > Theorem.
I have yet to see another 'portable' headphone amp with the drive capability and versatility of a micro iDSD. My HD650 plays beautifully using the micro iDSD in ECO mode. The 650 can be a bit dark sounding on some source material, and I find using the 3D option gives a nice subtle high frequency boost with these files.
I agree it scales well. I'm using hybrid tube amp, and I am actually using late 50s Amprex and Mullards. The DAC of the micro iDSD is definitely stronger than the amp section, and it scales very well. It doesn't have the dimensionality or resolution of some of the more expensive DACs I have used, but it has its own sound and personality. It's very good!
