- Mar 20, 2013
Bummer. I had to put in a ticket because both of my computers will not detect the iDSD micro. Just a flashing blue LED when off and a flashing green one when on. The USB software will not install because it says my device has to be plugged in...when it IS plugged in. I've read through about 200 pages here without finding an answer. 64-bit Windows 7. USB 2.0 and 3.0.
I'm at a loss. I guess I'll see what they say. I've never had a problem connecting anything to either machine.
Hi,
Am sure one of our staff will revert to your support ticket but in the meantime, your LED status can be checked here:
What the different Battery LEDs mean
http://ifi-audio.com/audio_blog/smartpower-please-feed-the-meaty-monster-part-1/
From your description, the battery needs a major charge from a high power (BC1.2, not Apple standard) port.
1) The iDSD micro cannot turn with flat battery, unless the USB port provides more than 0.5A current AND (crucial) is recognised as such by iDSD micro. So Apple is NOT recognised, so iDSD micro will not take more than 500mA.
2) If running in Eco mode with a full battery there will usually just about enough current from a USB port to run the iDSD micro, but it may on occasion nudge above 500mA, any other mode will need a BC1.2 port or it will take power from the battery. Such as running with HE-6.
Charging suggestions
http://ifi-audio.com/audio_blog/orico-high-power-usb-hub-one-sure-way-to-feed-the-meaty-monster/
You do not have to buy the Orico but it is one we have tested and recommend as we receive quite a few of these requests.
Also, if you have an iPad or Android charger check the rating as they are "higher power" than the standard iPhone charger and will get your micro iDSD up and running sooner.
The battery is very big and so it needs a major charge once out of the box.
Cheers.
For sure, one of our staff will get back to you on your support ticket.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
