tonyo442
bonjour, même volume avec prise 6.3 mm " L " et " R " ,
hello, same volume with 6.3 mm jack "L" and "R",bonjour, même volume avec prise 6.3 mm " L " et " R " ,
I am reading your question via following google translate;bonjour, serait il possible de nous dire ce qu'il en ait du suivi prise en compte du ifi pro ican, pour que nous puissions connaitre les réactions du constructeurs quand il y a un problème sur un de ces matériels, merci
I agree that the online translation still has a lot of room to improve (English - Japanese translation is usually terrible). If your own unit has an issue or a defect, I recommend you to open a support ticket regardless the warranty period is expired;la traduction n'est pas exacte,
il est possible de nous dire comment réagi le fabriquant de ifi pro sur la panne, merci
http://support.ifi-audio.com/
And see also below;
https://ifi-audio.com/warranty/
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Based on the characteristic of Tube+ mode, I recommend you to try some of the historical (I mean old) recordings with Tube+ mode if you own. Those are in general sonically harsh...such as remaining analogue hiss noise, thin tones, narrow dynamic range etc, even though engineers try to remaster them from original analogue tape by applying the most advanced digitizing technique.
Tube+Mode: Takes everything you get with tube mode but is a bit rounder sounding. Has a bit more bass presence as well.
