The Pro iCAN won't be alone for much longer...
Any chance you can post higher res photos?
There is a very thorough review of the ifi ican pro here
http://hifiphilosophy.com/recenzja-ifi-pro-ican/
but its in polish. Seems they recommend this amp very highly. They have experience with the rag, master 9 and more.
So, how much would you pay for a speaker/electrostatic add on? In that small a package it's likely to be a class d amp, but they could surprise us. Not likely to be super powerful for speakers, maybe 20-50 W/channel. I'm thinking no more than $600
I might have the wrong assumption. The energizer may not be an amp at all. It may be some sort on converter.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
For clarification, there are a few people in this thread that have not had issues with the HE-6. There was only 1 issue, which appeared to be an electrical issue either in the house or with the unit, as it was purchased in the UK but used in the US:
As for the ican pro and the HE-6: its great. Granted, I've never compared it to anything else (just because I don't have access to anything else even remotely powerful enough for the HE-6). But I think I know how these monsters are supposed to sound, and the ican pro drives these with authority, control, and finesse. It is clearly the best headamp I have (I did a massive comparison a few weekends back with all my cans, and they all sound the best on the ican pro).
Yeah, the guy who had problems never got around posting in the thread, if he got the problems fixed or not.
Otherwise, driving the HE-6, I'm wondering, is it the speaker-tap-like-great, which by veraciously some swear, or what's been said of Schiit Jotunheim-great
I wish I could help ya, but honestly, I don't have access to either: I sort of gave up on speaker amps a few years back and now just use my powered Stealth 8's (and probably will continue on this powered monitor bend for the future - I like how much it simplifies my system). There are a bunch of cheap class D amps out right now that I could pick up and test with the HE-6, but....whats the point in that?It just won't be better than the ican pro (though I'd love to be proven wrong)
Of course if anyone in new england has something to compare to, I'd be down for a testing session
An update on my iCan Pro that I thought had an issue with the protection circuitry kicking in - there's nothing wrong with the amp, the problem was solved by updating my chain with better suited components. The amp was previously being fed with a temporary dac that's really designed to be a recording interface, which I discovered outputs a very hot signal. I updated to a better quality stand alone dac with line level outputs, and now the iCan Pro doesn't switch off even at extreme volume on the HE-6. Good times!
Almost forgot to mention - When I first started using the amp, I didn't immediately notice a huge improvement in SQ on the speakers, but something happened when I finally unplugged the unit to ship it for a replacement. The same monitors hooked up to a "plain" iDSD micro started sounding metallic, a bit harsh even, which really surprised me. It's fascinating how I slowly grew to appreciate the new sound signature, but when whatever made it special was removed from the loop, the perceived change was quite apparent.
