iFi audio ZEN Stream - Streaming elevated to a higher plane
- Thread starter iFi audio
Mr BubbaHyde
Sponsor: iFi audio
I honestly never saw that, you should just be able to select Qobuz, then Play To and playWhat does this mean? Please see attached picture
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Mr BubbaHyde
Sponsor: iFi audio
This is the first screen I see when I open MConnect...
I think you've downloaded the wrong one, just use my link from the above post
Cheers!!
Cheers!!
Mr BubbaHyde
Sponsor: iFi audio
If that's your phone, I don't see a Wifi indicator, you must be connected to the same network the Zen Stream is.How to add Zen stream to Play to
I believe that's also true for Bubble
Cheers!!
Thanks Mr BubbaHyde got it now!
So no quality differences from lite to paid version? I want to stream Hi rez gapless.
One problem is I stream Hi rez file and light on Zen Stream is still yellow and not green. How come? This seems no better than Spotify.
Mr BubbaHyde
Sponsor: iFi audio
None that I know of, but that doesn't mean I am right, lolThanks Mr BubbaHyde got it now!
Stream High rez and check the Zen or DAC indicator to make sure, The way I remember it the lite version had ads that the paid version removed.
Now that you've got it, try Bubble as well to see which you like better!
Also in the menu of Mconnect is a gapless settings, you'll have to play with that as every DAC player is different, if you get a GAP, (Live Album, or Floyd) change it till you find the right one!
Now have a brew, and...
Cheers!!
Ok I just tried Norah Jones "It Was You" and stream light turn white!
Mr BubbaHyde
Sponsor: iFi audio
Lights have changed for Non Tidal Hi Rez files, I can't tell you what sounds better to you!One problem is I stream Hi rez file and light on Zen Stream is still yellow and not green. How come? This seems no better than Spotify.
Cheers!!
Many thanks Mr BubbaHyde!
Mr BubbaHyde
Sponsor: iFi audio
Hey guys!
For Zen stream do you guys prefer Tidal connect or Qobuz streamed through room or third party like Mconnect. I'm listening to Norah Jones "Come Away With Me" album in Hi Rez and wondering if FLAC I'm Tidal same.
Also my frequency is always yellow when streaming non Hi rez on Qobuz. I thought Qobuz is FLAC on stuff with no Hi Rez label so shouldn't Zen stream light be green? I remember when I had Tidal the light was green on most songs.
Any thoughts?
Any thoughts?
Does anyone know where could I find the upgrade changelog?
I have the device in DLNA mode and it's a burden to get it in AIO just to see if there's a software upgrade.
Thanks in advance!
Thanks in advance!
Thanks in advance!
This is the latest Beta version. Checked just now.
Total: 18 (members: 0, guests: 18)
