ryanwang0521
ifi zen dac Teardown
I bought it today, sounds excellent
ZEN DAC Black Label
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Yeah he is not at all impressed with the performance. The DAC performance is underwhelming and the amp is not clean enough to compete with the Topping's DX3 Pro or even the K5 Pro.Zen Dac coming tomorrow. audiosoundscience's Amirm reviewed Zen Dac, has measurements and comments posted on audiosoundscience website. Bottomline - he wasn't smitten with Zen Dac. Wish there was desktop amp/dac around $400-$500 with balanced 4.4mm. That's what I initially hunted for with no luck. Nothing I've seen meets that criteria, but if you know of something please direct me.
Were your observations made with the GTO firmware installed?
May send Zen Dac back unopened and wait for iFi, FiiO, other maker to release desktop amp/dac with 4.4 and newer class dac, or test with GTO filter firmware installed using balanced only. 4.4mm jack/inputs are going to be used more frequently by others I suspect, so it's a waiting game on new products incorporating 4.4. I read conflicting observations using iPower (or other 5V external power devices with Zen Dac). Being realistic, I remind myself it's a $129 desktop amp/dac, but downsizing from Hugo 2, should overcome my biases as what to expect.
Its not at all surprising that the Zen DAC doesnt measure all that well. Its using a hybrid multibit/delta sigma chipset so its never going to measure as well as one of the higher end Sabre/AKM delta-sigma chips. It actually measures very similarly to the other IFI dacs in the dac section, not surprising as they are all very similar designs.
Disappointing that the power output is less than spec, although that could be a issue with the USB port used for testing it. I think Amir is going to test it again with a power adapter so we might see a improvement over the USB only results. Subjectively I think its slightly louder with the power adapter plugged in so maybe it gives out more power.
The Zen DAC is "entry level". That is quoted from iFI themselves on this forum.
