iFi Audio Zen Dac 3... Plug In, World Out!
Jun 29, 2024 at 5:10 AM Post #271 of 398
There was some chat a few pages back about the Zen Dac 3 not powering off on computer shutdown when using USB power.
I went through the same thing with a different USB powered DAC and did some reading and discovered something that I didn't previously know was even a thing, it might be useful to somebody here.
On many/most computers the USB ports will still be powered even when the computer is shut down. That probably isn't a big deal but of course the DAC will light up and the battery of a lap top will be draining if left like that for an extended period of time.
The option to have power at the USB ports can be controlled, at least in some circumstances and some ports.
My scenario is a HP Z Book but the same likely applies to many others with different ways of achieving it.
I did a Google search about turning off USB power at shut down and found a raft of information, most of which was not applicable to my lap top. All sorts of settings within the Device Manager - Universal Serial Bus Controllers and Control Panel - Power Options and so on which ended up in dead ends with comments about settings that were not even there or didn't do anything if they were there.
However, I ended up with success in the BIOS (Basic Input Output System) setting, at least for the "Legacy" USB-A ports but not the USB-C ports, I could work with that.
There was an option to turn off USB power from the two "Legacy" USB ports (the USB-A ports) in the BIOS, literally uncheck a box and reboot. I could not find options for the USB-C ports.
The management options within the BIOS seem to differ wildly between manufacturers so I can't offer specifics but if you are stuck with a device that is constantly powered from the USB there may be a way to manage the USB power available at the ports after shut down. It will probably take some research to get to the BIOS and then to the right settings in the BIOS but there may be a relatively straightforward way to achieve unpowered USB ports after shutdown, at least in many situations.
Of course be careful messing around in the BIOS, you don't want to mess up something rather more critical.
Jul 1, 2024 at 9:24 AM Post #273 of 398
Yes I understand that.What I need to know is HOW do you turn ON the analog out?In other words.When you plug IN headphones,does that turn OFF the direct output through the RCA out on the back..And when you UNPLUG the headphones,does the DAC then output through the RCA out on the back?
From iFi:::"In this DAC as in other Zen series DACs, all outputs are active simultaneously.".........Well I'm not crazy about that but I suppose it keeps production costs down..
Jul 5, 2024 at 12:00 PM Post #276 of 398
Hey Folks, as an update I just wanted to share that there is a new firmware available for the ZD3 available on our downloads page...
https://ifi-audio.com/support/download-hub/
Here's some info for you...
Cheers!!
Jul 5, 2024 at 12:10 PM Post #277 of 398
Updated to V1.10, will play around with it and see if there's anything I notice and will check to see if the other lights now turn off. Thanks for the quick turnaround on the firmware update!
Hopefully people read the release notes closely, only update to V1.1C if you want to resample everything to either 352 kHz or 384 kHz. Upgrade to V1.10 if you want the "normal" experience. I would assume you can downgrade back to the standard firmware if you accidently upgrade to V1.1C without reading, hopefully?
Jul 5, 2024 at 12:20 PM Post #279 of 398
Is it possible to change the firmware from V1.1C to V1.10 just in case someone uses the wrong firmware?
Jul 5, 2024 at 8:06 PM Post #282 of 398
GTO Filter is Back? I always used it for gaming. Will try it out on the dac 3
Let us know you're impressions! Personally I was always a fan of the GTO filter, just loved the sound!
Cheers!!
Jul 28, 2024 at 8:45 AM Post #283 of 398
Wondering about this one and questyle m15i for desktop use mainly for IEM's and cannot decide :)
I listen lot of EDM but also other generes like nu disco, synthwave so not only bass counts.
Jul 28, 2024 at 9:03 AM Post #284 of 398
I had both and prefer the dac 3 with iems. Slightly warmer sound
