chaz_flhr
Soon to be owner of a 4.4 mm Pro iDSD should be here next week.
‘wouldn’t the best option be directly wired with cat 5 or 6, memory card or ssd connected to iDSD since it is a high end streamer?It will, but Pro iDSD just as any other DAC is also affected by a product before it. That's why you'd hear a difference between i.e. a laptop and expensive audiophile streamer.
Can you please tell me in what way one channel is lagging? Is it about volume level or something else?
the streamer is ok it’s more a secondary almost tertiary function , i run a pi as a streamer and it works super well‘wouldn’t the best option be directly wired with cat 5 or 6, memory card or ssd connected to iDSD since it is a high end streamer?
As a streamer would this be better or worse than streaming from a bluesound node 2i with MQA SQ wise?the streamer is ok it’s more a secondary almost tertiary function , i run a pi as a streamer and it works super well
Slightly worse but if you use a HAT like pi2aes it can beat thousand dollar DDCs for jitter performance , as for MQA meh lolAs a streamer would this be better or worse than streaming from a bluesound node 2i with MQA SQ wise?
I am hoping to move my node 2i to another location in the house.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Definitely the "Apodising" filter. If a song is poorly recorded and too bright-sounding for me, my default is to switch to that setting.can i ask which filter u consider the smoothest
So directly wired isn’t the best option?, my main goal is streaming Tidal hi-fi / masters and accessibility of my flac library on a 500gb Mirco sd card / ssd drive.It's worth trying out for sure and moving from there.
feeding data from source through a seperate unit is usually better due to jitter snd some other factors , if optical it’s inherently higher in jitter i’d go coaxialSo directly wired isn’t the best option?, my main goal is streaming Tidal hi-fi / masters and accessibility of my flac library on a 500gb Mirco sd card / ssd drive.
is the streaming end of this unit that poorly implemented or bad sounding?, doesn’t all incoming data through all inputs go through the same dac processes?, other than some inputs being bit-rate limited.
would I be better served feeding the iDSD from my node 2i optical or coax out for Tidal streaming?, or seeking a different option for my needs?
if i recall filters don’t work on samples above 192 before oversampling think that’s whyHey there,
MConnect, Tidal, 352 kHz Samples from 2L.
Why is there a "N/A", when i turn the filter button?
In my first tests i tried MQA directly and am pretty sure i got a blue or violett color too and was able to switch the Filter.
may i used another App? I couldn't remember.
If the signal is getting into the iDSD from the LAN connection raw and unfiltered wouldn’t the electronics and DAC inside the pro iDSD do a better job from start to finish on jitter and the other factors as well, rather than starting with the node 2i for first unfold?feeding data from source through a seperate unit is usually better due to jitter snd some other factors , if optical it’s inherently higher in jitter i’d go coaxial
MQA is bad regardless due to hidden higher noise on full unfold but that’ll i leave to you heh , gimme a sec i’ll link a good video on DDCsIf the signal is getting into the iDSD from the LAN connection raw and unfiltered wouldn’t the electronics and DAC inside the pro iDSD do a better job from start to finish on jitter and the other factors as well, rather than starting with the node 2i for first unfold?
currently only 5% of my FLAC library is in high res 24 / 192 with no DSD yet and thanks for the heads up on optical vs coax.
I get it you don’t like MQA and to you on your equipment it is not acceptable but for me on my equipment with 95% of my music files being flac @16 / 44 rips and a Tidal subscription, MQA is a big improvement over the 16 / 44 files to me, maybe I will try qobuz high res for comparison later on but I currently find MQA quite good.MQA is bad regardless due to hidden higher noise on full unfold but that’ll i leave to you heh , gimme a sec i’ll link a good video on DDCs
