iFi Audio Pro iDSD discussion thread
Aug 5, 2018 at 9:24 AM Post #2,071 of 3,460
Hey @iFi audio , did you manage to go into detail about the filters? I see a post saying "Stay tuned, coming up is Pro iDSD's digital filtering!" but I can't seem to find it
thanks!
Aug 5, 2018 at 12:42 PM Post #2,072 of 3,460
thanks!
It's not published yet but it will in the upcoming days.
Aug 6, 2018 at 3:15 AM Post #2,073 of 3,460
This may be a silly question, but the tube and tube+ modes, at which point does it affect the circuit pathway? I can hear clear differences in DAC only mode as I do not use the amp at all.
Aug 6, 2018 at 5:14 PM Post #2,074 of 3,460
After the d/a chip, passive lowpass and volume control if variable output/headphone out is selected (fixed output provides a 'hard bypass' of the volume control).
The input element of the line/headphone driver is selected to be either a cascoded J-Fet or the NOS GE Tube.
The Tube+ mode alters the internal circuitry to reduce the amount of negative feedback around the tube to almost zero.
This means that the tube's own harmonic (distortion) spectrum develops naturally, but measured distortion is relatively high.
The audible effects of doing this are covered to some degree by Bob Katz's article originally published here:
https://www.innerfidelity.com/content/katzs-corner-episode-25-adventures-distortion
There is no separate 'amplifier' in our iDSD Pro. As it is required to drive 200 ohm loads to as much as 10V in professional use, this product's line driver stage is able to directly drive most headphones.
The circuit path is as follows:
DAC in voltage out mode
RLC 3rd order passive lowpass filter
(volume control - if used)
line-driver/headphone driver
line/headphone selector relay
output connector (XLR+RCA or headphone jacks)
The circuit path is entirely direct coupled, Class A (except when driving very low impedance headphones to very high power levels).
The signal routing (volume control bypass and selecting the signal to be routed to line-out or hp-out) uses signal relays (by Omron - Japan) with gold over silver contacts hermetically sealed in a chemically inert gas.
To avoid using multiple relay contacts, the line/HP selection relays also function as 'mute' relays.
This makes for a signal-path as simple as possible to avoid signal degradation due to multiple unnecessary amplification circuits.
Aug 6, 2018 at 5:30 PM Post #2,075 of 3,460
Thanks for the reply. So you are saying I should hear a difference even in DAC only mode correct? That second part was too technical for me.
Aug 9, 2018 at 5:29 PM Post #2,080 of 3,460
Hi guys
Has anyone hd800s pair with pro idsd ?
How does comparison idsd black + Ican pro with pro idsd ?
I'm currently using this collection (idsd bl +pro ican)
But I'm not very satisfied .
Is it possible pro idsd Choose a better one?
Pro ican, of course, is broken, must be sent for warranty.:triportsad::triportsad:
Regurds Mori
Aug 10, 2018 at 12:31 AM Post #2,081 of 3,460
iFi, please help me clarify me on 2 things:
1. Does tube and tube+ circuit affect DAC only mode with the analogue outputs?
2. Is there any reason to use USB 3.0 cable over USB 2.0 as both work with the Pro iDSD?
Thx.
Aug 12, 2018 at 11:10 PM Post #2,082 of 3,460
[QUOTE = "Morimoriya 62, post: 14413429, membre: 459669"] Salut les gars
Quelqu'un at-il un HD800 couplé avec pro idsd?
Comment la comparaison idsd noir + Ican pro avec pro idsd?
J'utilise actuellement cette collection (idsd bl + pro ican)
Mais je ne suis pas très satisfait.
Est-ce possible pro idsd Choisissez-en une meilleure?
Pro ican, bien sûr, est cassé, doit être envoyé pour garantie .: triportsad :: triportsad:
Regurds Mori [/ QUOTE]
Aug 12, 2018 at 11:20 PM Post #2,083 of 3,460
hello, thank you for knowing the problem of ii pro ican, thank you
Aug 13, 2018 at 1:13 AM Post #2,084 of 3,460
I reckon, get rid of the Pro iCan and iDSD BL and get the Pro iDSD.
Aug 14, 2018 at 6:55 PM Post #2,085 of 3,460
Folks, awesome news!
EISA (the European Sound and Imaging Association) has awarded the xDSD as the Best Portable DAC/Headphone Amplifier for 2018-2019.
The official release is to be found here:
https://www.head-fi.org/threads/ifi-audio-xdsd-the-official-thread.873787/page-56#post-14422901
HAPPY!
