iFi Audio Pro iDSD discussion thread
Discussion in 'Dedicated Source Components' started by jwahl, Jan 26, 2014.
128 129 130 131 132 133 134 135 136 137
139 140 141 142 143 144 145 146 147 148
  1. bluesaint
    The Chord Elite's would be Dave or Hugo 2 not Qutest though.
  2. gordec
    As a pure desktop DAC, Qutest is better than the Hugo 2 with variable output, better inputs.
  3. melons
    I was under the impression that iPurifier3 etc only added an advantage if you were using mains (AC supply) or playing via a laptop?, but no SQ benefit if you're, for example running the iDSD BL via a DAP, both running on their battery?, is this correct?
    Squonk12 likes this.
  4. gordec
    Anyone tried to connect the iDSD to the their router via ethernet? I know it doesn't act as Roon endpoint, but does it work well as a server streaming using Muzo?
  5. iFi audio
    Please share more if you can!
    iFi audio Stay updated on iFi audio at their sponsor page on Head-Fi.
    https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ info@ifi-audio.com
    alphanumerix1 likes this.
  6. Condocondor
  7. gordec
    Anyone knows if I can use regular USB 2.0 A-B cable for iDSD?
    Edit: Nevermind. Tried one of the 2.0 cables. Works great.
  8. iFi audio
    Condocondor likes this.
  9. tonyo442
    Hello, thank you for reading, I will order the ipurifier usb 3, thank you
  10. gordec
    Is anyone able to hear any difference between the different filters? If I hear any difference it's very subtle. That also goes for DSD512 and DSD1024 remastering.
    It's also interesting that the PCM upsampling fiters like Bitperfect+, Gibbs Transient Optimised, etc also work under the 2 DSD remastering modes. Is this the way it's intended?
  11. Baten
    I do wonder if the PCM filters can be applied in conjunction with the DSD remastering function.
  12. gordec
    Currawong likes this.
  13. gordec
    If you upsample a nonDSD file to DSD512/1024, iDSD first oversamples to 705.4/768kHz. None of the filters applies in those 2 modes. You can turn the knob, and may appears that you are switching digital filters, but they are not doing anything.
    If you play a native DSD file, iDSD will only play it in bitperfect mode. If you upsamples a native DSD file to DSD512/1024, there is no bitperfect mode because a digital filter has to be applied.
  14. iFi audio
    :beerchug:
    :beerchug: #2
  15. tonyo442
    hello, did some try USB 3.0 instead of 2.0,
    USB 3.0 is much faster than USB 2.0, I did not find it useful to use ipurifier 2
