iFi Audio presents iDSD Valkyrie
Mar 31, 2025 at 3:09 PM Post #211 of 329
If you were to write a review yourself how many people would trust it haha? :)
Exactly! I am a big fan of it in terms of sound, but I would never try to write a review for it as I don't have the "Chops".
If anyone asks I tell them what I hear, what I feel about the product, numbers and the like mean little to me, and lots to others. Another reason for me not to do a review...:ksc75smile:
Cheers!!
Apr 1, 2025 at 8:07 AM Post #212 of 329
We will be at AXPONA in Chicago in just a short time, so if you're nearby or already attending, you can check out the Valkyrie for yourself!
APRIL 11-13, 2025
Schaumburg Convention Center | Chicago, IL
https://axpona.com/
Cheers!!
Apr 1, 2025 at 8:34 AM Post #213 of 329
If you could write an essay that got at a B, you can write a review. Follow basic good writing practice.
Tell your readers your background and likes and dislikes.
Explain how you felt using the product was. Be honest, but try to avoid outright negativity.
Avoid damning with faint praise, if you didn't like something, be clear, but also if it's something subjective, be clear that it is, like "I prefer buttons/sliders/rotaries/touchscreen/app on phone for volume (delete as appropriate) and this used my least favorite option".
Be direct if you liked or disliked a sonic trait.
Keep it simple, less words are more. Avoid flowery vichyssoise of verbiage and empty wankwords and wank phrases.
It is difficult to express sonic performance in words, but there is relatively standard terminology, I remember from my reviewer days a general cribsheet of "audiophile terminology", find it, use, refer your readers to it as reference.
I would avoid making 70% of the review copy & paste from the manufacturers literature, refer peeps by link. Instead try to bring out what makes the device unique (if anything) compared to other widgets.
If you do a video review, that's harder. You must be able to project across the fourth wall, scrips are pretty much necessary (I'm totally sh!te doing ad hoc at least) and you need to be entertaining to keep peeps watching.
That's tough sh!t, if you do it well though you can monetise pretty big on u-toob and other sites and afford to be honest and independent.
Thor
Apr 1, 2025 at 8:57 AM Post #214 of 329
Speaking of reviews...
Headfonia has posted their review; a big thank you to Rudolfs for the thoughts!
https://www.headfonia.com/ifi-audio-valkyrie-review/
Cheers!!
Apr 1, 2025 at 11:56 AM Post #216 of 329
APRIL 11-13, 2025
https://axpona.com/
Cheers!!
Hoping to spend a deal of time listening to Valk, compare with my gryphon to see how big of an upgrade I'm giving myself if/when i get my own valk
Apr 2, 2025 at 3:29 PM Post #217 of 329
Here's a longer review (In Korean), but there are some audio examples in there. A big thank you to Producer dk for the rundown...
Cheers!!
Apr 3, 2025 at 4:18 AM Post #218 of 329
Just dropping in to ask about the battery bypass mode and if the new Valkyrie has it or not.
I searched the thread but I couldn't find an answer and neither any on the reviews that have been posted from different sources.
My iDSD Micro BL is still working great but I had nothing but constant headaches with the Gryphon batteries unfortunately.
Apr 3, 2025 at 5:18 AM Post #219 of 329
Me and some others have asked the same question. I was giving them some time to clarify this.
May be they are dodging the question as they also did with Gryphon back then because it did not support battery bypass.
@iFi audio It’s been a week now since you said you will get more information. Any update on this ? Why don’t you give us a simple “Yes” or “No” and then we can move on ? :)
Question is simple: Can the Valkyrie run purely on mains without using or charging the battery ?
Apr 3, 2025 at 8:26 AM Post #220 of 329
That is because the Gryphon battery pack is made from two batteries of different size/capacity (to allow for the noisy OLED screen prone to screen burn). That's basically a big no-no.
All iFi products with a single battery or those with multiple identical batteries should be fine.
I actually have the same problem with my Xiaomi laptop. Third battery pack now. Cheap enough and otherwise it's a great laptop. But the battery pack is made from multiple unequal size/capacity cells and it's always the small cell that gets puffy.
Thor
Apr 3, 2025 at 10:41 AM Post #221 of 329
My apologies. I thought I had posted what I had received.
"There are two situations: (1) charging in the off state. When the battery is full, Valkyrie will completely turn off and stop charging; (2) charging in the on state. Valkyrie will stop charging, switch to battery power supply after stopping charging, until the battery power drops to a certain level, then recharge."
"Now, iDSD Valkyrie has added a battery health usage mode option on the basis of the original one. That is, when the battery charge reaches 90%, charging will stop. When the battery level drops below 5%, it will be forced to shut down."
Hope this helps...
I know of nothing that points to the ability to run purely off mains, if I get further info I will post up if/when I get it
Cheers!!
Apr 3, 2025 at 5:15 PM Post #224 of 329
Yea i was really hoping it had bypass mode, but maybe next time 🤷‍♂️
Apr 3, 2025 at 5:51 PM Post #225 of 329
Surely to goodness on a device that is fundamentally for desktop use there has to be a true "desktop mode" in respect of mains power and battery management !
It utterly beggars belief if there wasn't one to the extent that I suspect we are simply not getting the right information.
I am happy to be proven wrong but it seems utter idiocy if it doesn't have that basic feature, a $200 FiiO device has it for goodness sake.
