srkbear
That’s very odd. Are you using the 4.4mm to 4.4mm balanced analog connection between the two? If not run over to Amazon and buy the cable—that’s definitely the only way to do it justice…The internal DAC. I noticed that it sounds great after about twenty minutes, then sounds awful after about an hour; harsh and flat. I'm using it with the Zen can 6xx (balanced out from the NS)
4.4mm Male to Male Balanced 5 Pole 8 Core Silver Plated Headphone Adapters Cable Aux Cable 4.4mm to 4.4mm Balanced Cable https://a.co/d/cOndfqm
Edit: I just caught that you’re using a balanced connection. I assume that’s via the pentaconn connection? I can’t explain why you’d have any degradation of sound after 20 minutes. Is anything getting excessively warm? Are all your cables sound? It really isn’t a burn-in issue, and it’s hard to say anything useful based on the way you’re describing the audio changes…
