SubSTI
- May 22, 2014
You need to be a member of the iCLUB to beta test....Apparently I am not i (enough).
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Another Alclair owner. Did you get your impressions from the Alclair -Tennessee shop?
Hi,
Nice spot!
v4.02 is the latest official firmware for the nano iDSD
v4.06 is the latest official firmware for the micro iDSD
BETA v0.16 is for both the nano iDSD and micro iDSD (and also soon-to-be launched Stereo 50).
Originally (a few years ago) we used the XMOS chipset and was reliant on the XMOS software.
But as we knew the XMOS chipset was under-utilised, over time, we brought this in-house which has enabled us in Subaru WRX terms to do a ProDrive and "remap" the XMOS chipset (as evident from the Quad DSD256 and Octa-DSD512/768kHz levels attained).
Our code is now 100% in-house; and soon all iFi products will move over to the same, iFi XMOS firmware platform.
The upcoming iDAC2 will of course also run on this same iFi coded platform.
Cheers.
Hi guys,
I´ve encountered a bit of problem with my iFi nano. While playing DSD file, the volume control of foobar is completely inactive, the only thing I am able to change the volume is the volume knob on Nano itself. The problem is, that for my Hifiman HE-4 the volume isn´t simply enough, while for FLAC files I run some 3/4 of volume potential, on DSD file I can even go to max volume. I suspect some setting in foobar to be the cause but dont know which one. Anyone any idea?
Thx for help
Hi guys,
Thx for help
Don't know how, but you simply need Foobar to output full level, then use the Nano as an analog attenuator. May be this is what is happening at present? I have my Nano turned 3/4 to full with any file type.
If your Foobar is set to output DSD to iDSD nano, then no digital control is the right thing (Foorbar automatically disables volume control on DSD anyway).
Real DSD CAN NOT have an digital volume control, that's the reason why it doesn't and shouldn't work. The reason is, digital volume control works by reducing the bit depth of the digital files to reduce its loudness, and every -6dB means 1 bit of bit depth is lost.. Given DSD is a ONE bit format, reducing it by a mere -6dB will totally turn it into, well, a big nothing. That's why you will never want to apply any digital volume control to DSD. If you ever see a DSD playback that offers digital volume control, it usually means the data has been internally converted to PCM, followed by the usual digital volume control, then output to hardware.
Also, DSD is normally -6dB less in volume when compared to PCM. So getting less volume is normal as well.
Hi guys,
Thx for help
The iFi nano iDSD is designed for portable use with portable headphones.
The HifiMan HE-4 is not a portable headphone, it is a power hungry behemoth.
You need a micro iDSD.
Yeah, I know, I´ve had Schiit asgard, but after buying nano, I didnt like the sound of it, so I sold it, although it might have been sufficient for HE-4 powering. Never mind, I will have to save some gold and buy the Micro.
Today my Nano arrived.
It sounds great, and has enough power do drive my fidelio x2 well. it´s my first DAC/Amp and i really like it!
But i have a little problem,
I installed the driver, set audio out to it, but i can´t select 384khz?
I Installed the latest Driver 2.23 and i use windows 8.1.
Annyone had the same Problem and know how to solve it?
